lwinger
Posted: Tue Jul 21, 2009 10:41 am Post subject: Canopy weather stripping |
What have you used (or seen in use) for sealing between two areas: (1) the canopy front edge to the forward top skin, and (2) between the two rear "hoops" in addition to the flashing?
| | - The Matronics Zenith650-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Zenith650-List |
_________________ Larry Winger
Tustin, CA
Plans building 601XL/650 with Corvair
Installing fuel system
www.mykitlog.com/lwinger |
Posted: Tue Jul 21, 2009 11:55 am Post subject: Canopy weather stripping |
Larry,
I've seen one HD with just a trim strip on the fuselage forward top skin
that provided a good fit and cushion for the bare edge of the canopy. I
used the typical 3/4-inch
rubber edge with a slot for the canopy and glued it a drop at a time
1-inch spacing with crazy glue to keep the stuff inside the slot. Both
these systems work well.
Neither needed the flashing with such a good fit between canopy and skin.
lwinger wrote:
Larry Winger
Tustin, CA
Fuselage on gear
Canopy nearly complete
http://forums.matronics.com/viewtopic.php?p 54152#254152
