wcurtis(at)nerv10.com Guest
Posted: Sun Jul 12, 2009 7:23 am Post subject: Spinner Back Plate Spacer |
I'm fitting the prop with an old Hartzell hub and I need to know the hight of the spacer specified on page 47-02 Figure 1 - Spinner Back Plate assembly.
William
40237 - http://nerv10.com/wcurtis/
orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
Posted: Sun Jul 12, 2009 9:15 am Post subject: Re: Spinner Back Plate Spacer |
| wcurtis(at)nerv10.com wrote: | I'm fitting the prop with an old Hartzell hub and I need to know the hight of the spacer specified on page 47-02 Figure 1 - Spinner Back Plate assembly.
| Not sure if I can help with the plane at the hanger but are you wanting to know the thickness of the S-602-1, its diameter, or the Doubler Ring S-602B or ??? Not sure what you mean by 'hight'
_________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
Posted: Sun Jul 12, 2009 10:17 am Post subject: Spinner Back Plate Spacer |
William, unfortunately, I can't get a gauge on the spacer or the
doubler. I assume you are looking for the thickness of the spacers in
Figure 2 rather than the doubler in figure 1.
William Curtis wrote:
| Quote: | I'm fitting the prop with an old Hartzell hub and I need to know the
Plate assembly.
William
Posted: Sun Jul 12, 2009 11:04 am Post subject: Spinner Back Plate Spacer |
Bill,
Yup, you are right it is Figure 2. It looks like the part number is S-604 and the height is 1/4", Larry Rosen confirmed this for me. This spacer is between the prop hub and the spinner backing plate as depicted in chapter 47 Figure 2.
Since I did not have a new prop that I'm using to fit the spinner and cowling, I did not have the appropriate spacers. I'm fabricating the spacers for fitting purposes. Thanks for the help.
William
On Sun, Jul 12, 2009 at 2:12 PM, Bill Mauledriver Watson <MauleDriver(at)nc.rr.com (MauleDriver(at)nc.rr.com)> wrote:
[quote]--> RV10-List message posted by: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com (MauleDriver(at)nc.rr.com)>
William, unfortunately, I can't get a gauge on the spacer or the doubler. I assume you are looking for the thickness of the spacers in Figure 2 rather than the doubler in figure 1.
| Quote: | I'm fitting the prop with an old Hartzell hub and I need to know the hight of the spacer specified on page 47-02 Figure 1 - Spinner Back Plate assembly.
William
http://www.matronics.com/Navigator?RV10-List< - MATRONICS WEB FORUMS -
= --> h
a href="http://www.matronics.com/contribution" target="_blank">http://www.matronics.com/contribution
N777TY
Joined: 09 Apr 2006 Posts: 69 Location: Charlotte, NC
