jonlaury
Posted: Thu Jul 16, 2009 7:56 am Post subject: Solid State Relays |
Saw these http://www.futurlec.com/RelSS.shtml
and for $20 they look like possible replacements for the common electro-mechanical relays that we now use. These are light, compact, and very reliable. But I don't know if there are gradations of MOSFETs or if they're just basic building blocks. The cost of these is about 1/8 of an almost identical Teledyne unit and I wonder if "you get what you pay for" is appropriate to apply here? Or is Teledyne just passing on the costs of marketing, regulatory environment, lawyers, pensions, etc?
The only obvious downside that is evident from the data sheet is that the load capability starts falling off at about 60 deg C, so installation in an engine compartment is off the table without a blast tube and heatsink.
One of these has a load spec of 240VAC (at) 70A and another specs 100VDC (at) 40A. I'd rather have more amperage capacity. Do solid state relays care whether the load is DC or AC?
What think you all?
John
jonlaury
Posted: Thu Jul 16, 2009 8:41 am Post subject: Solid State Relays |
OK, I should've gone to the archives BEFORE I posted this thread.
But the objection 11/2 yrs ago was a voltage drop of 1.5 (at) 12v. These claim .35v (at)30V. Did the earlier versions claim a similarly low V drop?
I guess the only way to be sure is to buy one and test it.
JB
mprather(at)spro.net Guest
Posted: Thu Jul 16, 2009 9:20 am Post subject: Solid State Relays |
If I read the data correctly, it appears these relays are only rated at 3A
continuous which even fairly small switches can handle. Not sure why
you'd pick the relay over a switch unless you wanted to use a micro-micro
switch to control something.
Also, a few other issues:
- It's rated for AC. Not sure how it will perform controlling a DC load.
- The forward voltage drop seems like it might be large - up to 1.5V at
peak current. Not only is that a bit of a performance hit, it will
generate some heat. The app notes specify to provide adequate
ventilation.
- Don't know what behavior you might see if the load tried to drive the
source - might not be bidirectional.
Matt-
| Quote: | Saw these
for"
| Quote: | is appropriate to apply here? Or is Teledyne just passing on the costs
of
| Quote: | marketing, regulatory environment, lawyers, pensions, etc?
the
| Quote: | load capability starts falling off at about 60 deg C, so installation in
heatsink.
What think you all?
John
retasker(at)optonline.net Guest
Posted: Thu Jul 16, 2009 9:53 am Post subject: Solid State Relays |
I think you may have looked at the wrong part. You have to go down to
the bottom of the page to find the high amp rated DC units.
That said, see my previous email.
Dick Tasker
Matt Prather wrote:
ventilation.
Matt-
The 0.35V drop only applies to the low voltage assemblies which are not
listed at Futurlec. They only show the 100V and 200V for sale and they
have a much higher voltage drop at a lower current.
The 30V versions look very attractive with the 0.007 milliohm on
resistance at 50A.
However, they say nothing about reverse voltage, so I would have to
assume that these are only good for supplying power to a load and not
good for use where there could be a reverse voltage on them - such as
what would occur if you were trying to use two of these to switch two
different batteries to a common load.
Dick Tasker
John Burnaby wrote:
| Quote: | OK, I should've gone to the archives BEFORE I posted this thread.
JB
