floydgm(at)hotmail.com Guest
Posted: Fri Mar 24, 2006 6:45 pm Post subject: MR RPM Turbos |
Just need to share the news in Commander land. I have been working with Dick
MaCoon and Arnold Blankenship of Firetruck Aviation in Centerville Tennesee
to put together an updated turbocharger conversion.
Commander 500S N210HD sports 4 RayJay turbos, Inconel wastegates, updated
actuator system (no cables) linear electric actuator, electronic wastegate
controller with manual override.
Relocated oil cooler.
No scavange pumps, improved gravity drain system.
A general clean up program to improve maintenance access and reliabilty.
Final STC certification details are pending but she will fly legally with a
DER's 8110 form.
System is based on the original RayJay STC and MR RPM improvements. Test
flights are scheduled for next Wendsday.
STC will cover 500B,U,S. and will feature a gross weight increase.
Bragging a bit but she will have all of a freight dog's maintenance
improvements, my contribution. She only makes a living when she flys. She
must be reliable and maintainable.
Contact Arnold or his most capable wife Charlene at 931-729-0007. Arnold is
the holder of the MR RPM STC's and tooling.
Or myself Mike Floyd 509-886-1036
Mike Floyd
Commander NW LTD
| | - The Matronics Commander-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Commander-List |
john(at)vormbaum.com Guest
Posted: Fri Mar 24, 2006 7:40 pm Post subject: MR RPM Turbos |
Hi Mike,
Quick question: I have a 500B with the original rayjay system installed
(electric wastegates). Is this a complete new installation, or is there a MR
RPM "upgrade" available? Additionally, can this package be offered on the
newer "wide-deck" IO-540's? I'd like to switch to those engines at some
point.
Also, can you share some information on the cost of the conversion/upgrade?
/John
CloudCraft(at)aol.com Guest
Posted: Fri Mar 24, 2006 7:54 pm Post subject: MR RPM Turbos |
In a message dated 24-Mar-06 18:46:30 Pacific Standard Time,
floydgm(at)hotmail.com writes:
Sounds perfect! More questions:
How does one over ride the electric turbos without cables?
This must be full-time turbo-normalization, right?
Wing Commander Gordon
Life is not simple anywhere. Probably less so elsewhere.
Posted: Fri Mar 24, 2006 8:23 pm Post subject: MR RPM Turbos |
No the later wide deck engines are not supported thank Lycoming for that.
The original narrow deck IO-540s are supported. And so are the original
RayJay installations. No price info yet but if you have the system intalled
the upgrades are available.
Posted: Fri Mar 24, 2006 8:25 pm Post subject: MR RPM Turbos |
The electronic wastegate controllers can be overridden by the manual control
switches.
Posted: Fri Mar 24, 2006 11:58 pm Post subject: MR RPM Turbos |
Mike,
Thanks for the response. I'm excited to see what the finished product looks
like.
/John
Posted: Sun Mar 26, 2006 8:15 am Post subject: MR RPM Turbos |
The electronic control box for the linear actuator is turned off by a switch
in the cockpit and it reverts to a manual open, closed switch system.
Posted: Sun Mar 26, 2006 9:35 am Post subject: MR RPM Turbos |
In a message dated 26-Mar-06 08:16:23 Pacific Standard Time,
So, in the event of power failure or simply circuit fault, does the waste
gate fail to full open or does it fail to present position?
Posted: Sun Mar 26, 2006 1:19 pm Post subject: MR RPM Turbos |
It fails to the present position in either instance. It would then be up to
the pilot to control MP. using the throttle.
tylor.hall(at)sbcglobal.n Guest
Posted: Sun Mar 26, 2006 1:59 pm Post subject: MR RPM Turbos |
Mike,
Were you able to work in the intercoolers. When I was talking to
Dick, he had designed the intercoolers to be under the cowling with a
little scoop and the scoop for the oil cooler would be behind the
firewall in the wheel well. Has that configuration worked out?
Could an existing conversion add the intercooler and oil cooler?
Those two thing would help keep the engine cooler?
It is great to see those STC in hands that know what they are.
Tylor Hall
On Mar 26, 2006, at 2:18 PM, mike floyd wrote:
<floydgm(at)hotmail.com>
be up to
Posted: Sun Mar 26, 2006 2:02 pm Post subject: MR RPM Turbos |
In a message dated 26-Mar-06 13:20:30 Pacific Standard Time,
That was the answer I was hoping for! Sounds like yet another well
thought-out Mr. RPM innovation.
OK ... more questions. Hope you don't get annoyed, but I've been waiting for
this news for years.
Does the package use an updated EGT or TIT? (Don't get started on that
thread again, lads.)
I'm sure the STC would not specify a particular EGT or TIT gauge (so the
installation leaves it to the owner's discretion) but am curious if Mr. RPM is
advocating one reading over the other for the updated equipment.
Thanks!
Posted: Sun Mar 26, 2006 2:27 pm Post subject: MR RPM Turbos |
Yes the oil coolers have been moved behind the firewall. Works out well. No
development of the intercoolers yet.
The existing conversions could incorporate the oil coolers.
Between relocating the coolers and cleaning up the ducting and turbo oil
system it makes the engine compartments much easier to work in.
Posted: Sun Mar 26, 2006 2:58 pm Post subject: MR RPM Turbos |
No the STC will not have an EGT or TIT system specified. No I have never
discussed this with MR RPM. Both systems give you the same basic
information, where is the engine operating in relation to peak temp.
nico(at)cybersuperstore.c Guest
Posted: Sun Apr 02, 2006 9:19 pm Post subject: MR RPM Turbos |
Tylor,
I uploaded your pictures to
http://www.teletuition.org/panels.htm and click on 4-01-2006
Nico
Posted: Tue Apr 04, 2006 9:14 pm Post subject: MR RPM Turbos |
Folks,
The new panel photos of Tom's Mr. RPM hvae been uploaded to
http://www.teletuition.org/panels.htm and click on Panels and then 04-04-2006.
Enjoy,
Nico
