				 Posted: Wed Jul 15, 2009 2:41 pm    Post subject: gas |
				no.....  (just HAD to say that:)
 Very pretty day here for once.  Actually made it to 80F.  I was
 puttering around on the car,
 getting it ready for NYS inspection but really felt the urge to
 aviate.  As I have previously posted
 I had been having mysterious fuel/carb problems.  Thought I gone
 through just about everything and
 the plane seemed ok.  While it was warming up and I was wiping bug
 crap it died.  -That took the edge off my
 enthusiasm.
 I knew it was still fuel.  I pulled the line off the filter and ran
 the master.  Yellow fuel came out followed by a lighter color.
 I cleaned the float valve with carb cleaner,  drained the tank and
 refilled with fresh.  Purged some more and hooked it back up.
 Seems ok again, visited a couple of neighbors,  made a go-around over
 the trees on one guy's short lumpy strip
 after a bounced landing.  Still getting used to those legs.
 I don't like that gas problem.  Never had it before after 40 years of
 running car gas.  My neighbor winters near Ft Meyers
 and was talking to a boat dealer there.  Said he has never had as
 many boat engines suffering fuel problems.
 BTW, I DO clean the tanks every spring and put in fresh gas and
 change the filter.  The stuff I took out of the tank today
 was definitely darker in color than the fresh gas.  All I can advise
 is to pour a sample of every can into
 a clear container and look at it.
 I hate &%#? ethanol.
 BB
 MkIII  suzuki
				 Posted: Wed Jul 15, 2009 2:50 pm    Post subject: gas |
  	  | Quote: | 	 		   change the filter.  The stuff I took out of the tank today
  was definitely darker in color than the fresh gas.  All I can advise  is
  BB
  MkIII  suzuki
 Bob B:
 I have been running more 100LL than mogas lately.
 Since I don't fly much locally any more, I like having 100LL in the tank and
 fuel system.  It stores much better than ethanol laced fuel.  No problems
 yet.
  _________________ John Hauck
Titus, Alabama |
				 Posted: Wed Jul 15, 2009 3:12 pm    Post subject: gas |
				John,  I think I will start doing that too, especially considering
 how few hours I fly anyway.
 This gas situation gives me the willies, heebie jeebies, and there's
 a golfer's term for it too,I forget. (the YIPS?)
 Say hi to the folks in PA and if you are ambitious and the weather is
 bad going home, stop up here and
 cool off. I'll buy you a tank of 100LL
 BB
 On 15, Jul 2009, at 6:46 PM, John Hauck wrote:
 > advise  is to pour a sample of every can into
 > BB
 > MkIII  suzuki
  Bob B:
  tank and fuel system.  It stores much better than ethanol laced
  fuel.  No problems yet.
		donaho1(at)verizon.net Guest
				 Posted: Wed Jul 15, 2009 4:11 pm    Post subject: Gas |
				Just this year I started using Marine Sta-Bil in all the 92 octane gas I
 run in the 503. It says it will take care of all the things that concern me
 about ethanol. We will see. Lanny FSII
		lucien
				 Posted: Wed Jul 15, 2009 7:03 pm    Post subject: Re: Gas |
				Pure auto gas went away here completely a few months ago so I started running it around that time. Fortunately no problems as the tank was already very clean to begin with.
 What I do is start robbing gas out of the plane with the siphon if I don't get to fly for longer than about 2 weeks. I burn it in the truck which usually needs gas anyway.
 This way, the tank always has freshly pumped gas in it one way or the other when I go fly. We live in a dry climate so this may be a little paranoid I'll admit but it has worked to keep my fuel system clean so far.
 I've been lucky and have been able to go up and get the motor to operating temp at least once a week but sometimes I'm grounded longer than that.
 There's an attempt being made now to increase the ethanol concentrations to 15% by the ethanol industry. If it goes through (and I'll bet a million that it does) then I'll have no choice but to go back to 100LL. 100LL keeps a lot better anyway as John H. says.....
 LS
  _________________ LS
Titan II SS |
		herbgh(at)nctc.com Guest
				 Posted: Wed Jul 15, 2009 7:15 pm    Post subject: Gas |
				Wondering if a quart of av gas mixed with a tank of rot gut would act
 similarly to Sta Bil?   Herb
 At 07:04 PM 7/15/2009, you wrote:
 gas I run in the 503. It says it will take care of all the things
 that concern me about ethanol. We will see. Lanny FSII
 Checked by AVG - www.avg.com
 07/15/09 17:58:00
		Jean Bilodeau
				 Posted: Thu Jul 16, 2009 3:28 pm    Post subject: Re: gas |
				The main concern about fuel containing ethanol is that the fuel lines are not necessarily compatible and may actually start to dissolve from the inside. This will lead to partial and even total blockage. The same is true for fuel containing <cleaning>. I used it once in my Pietenpol and is made my fuel gage float swell to the point where I had to destroy it to get it out of the tank. if regular fuel is no longer available, the choices are Avgas or marine.
		lucien
				 Posted: Thu Jul 16, 2009 3:35 pm    Post subject: Decalin Runup |
				Speaking of 100LL, has anyone noticed any benefit from using Decalin Runup? I noticed it was approved for use in the 912 in the latest SB (where E10 was approved), but Rotax merely said it did no harm....
 On the occasions I run 100LL, I might use the Decalin to help keep 'er clean, if it actually works....
 LS
Titan II SS |
