FIRST FLIGHT
GLJSOJ1
PostPosted: Sun Jul 05, 2009 5:38 pm    Post subject: FIRST FLIGHT Reply with quote
Hi everyone.
Made my first flight today at KCPK just before lunch. I just finished my
BFR yesterday after not flying for almost two years. I have several issues to resolve, but most of these should be minor. I lifted off at 60KIAS and SLOWLY climbed out. Top speed was 105 KIAS.
The issues are prop is pitched too steep, so climb was poor.
Overheating of engine
Very heavy left wing.
If anybody has information on what was done to correct that heavy left wing I am all ears.
I'll work on the the cooling issues first as they are the simplest to fix and I hope to get some suggestions for the wing issues. First thing I am going to look at is the aileron rigging.
Thanks to all that gave me advise these past year or so.
601XL N676L FLYING PHASE I
CHESAPEAKE VA
leinad
PostPosted: Sun Jul 05, 2009 5:52 pm    Post subject: Re: FIRST FLIGHT Reply with quote
Glenn,
I want to offer you my congratulations. You built and flew your own plane! I hope to join you soon.. Right now I'm rebuilding a wing I messed up when drilling the skins. Argh!
Dan
GLJSOJ1 wrote:
Hi everyone.
n801bh(at)netzero.com
PostPosted: Mon Jul 06, 2009 5:12 am    Post subject: FIRST FLIGHT Reply with quote
Congrats to you for another Zenith in the air. !!!!!!!!!!!!
As for your issues, Is the prop adjustable?? is so a very easy fix. What kind of engine are you using? Heavy left wing is heard all the time. How was your corner weights when you did you weight and balance?
Ben Haas
N801BH
www.haaspowerair.com
Gig Giacona
PostPosted: Mon Jul 06, 2009 5:12 am    Post subject: Re: FIRST FLIGHT Reply with quote
GLJSOJ1 wrote:
Hi everyone.
Congratulations.
I have a question in regards to heavy left wing. When you weighed the plane what were the weights at each wheel?
W.R. "Gig" Giacona
601XL Under Construction
jeffrey_davidson(at)earth
PostPosted: Mon Jul 06, 2009 5:40 am    Post subject: FIRST FLIGHT Reply with quote
Congratulations Glenn! You are off the ground and flying. What a great accomplishment. I have my Airworthiness Certificate now and I'm right behind you up here in Warrenton, VA. The Mid-Atlantic area is Zenith country! It was great meeting you at Suffolk. I'm working on the Winchester Zenith Gathering and will announce it soon.
Jeff Davidson
Time: 06:42:25 PM PST US
Subject: FIRST FLIGHT
Hi everyone.
all ears.
601XL N676L reserved
ALMOST DONE
CHESAPEAKE VA
Jeyoung65(at)aol.com
PostPosted: Mon Jul 06, 2009 6:22 am    Post subject: FIRST FLIGHT Reply with quote
If the weight on each wheels are about the same, try adjusting the left aileron down a light (1/2 to 1 degree). Jerry of GA DO NOT ARCHIVE
In a message dated 7/6/2009 8:17:05 A.M. Eastern Standard Time, wrgiacona(at)gmail.com writes:
--> Zenith-List message posted by: "Gig Giacona" <wrgiacona(at)gmail.com>
GLJSOJ1 wrote:
Hi everyone.
Congratulations.
W.R. &quot;Gig&quot; Giacona
http://forums.matronics.com/viewtopic.php?p=251712#251712===============================================
_-= the ties Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp;   ===================================================
Looking for love this summer? Find it now on AOL Personals.
ronlee
PostPosted: Mon Jul 06, 2009 6:23 am    Post subject: Re: FIRST FLIGHT Reply with quote
You need to put a trim tab on the right aileron angled down for a heavy left wing. This will take the pressure off the stick as it will be doing the same thing as you are doing manually to keep the left wing up. The trim tab always has to be pointing down and on an aileron. The air under the wing is undisturbed, even in a stall. If it is pointing up, it loses its effectiveness as the air over the top of the wing starts to burble, such as in a near stall. Several have adjusted the ailerons thinking that will work, but all it does is put the stick off center in flight.
Ron Lee
Tucson, Arizona
kmccune
PostPosted: Mon Jul 06, 2009 7:10 am    Post subject: Re: FIRST FLIGHT Reply with quote
Congrats!
Kevin
“Always do what you are afraid to do.�
R.W. Emerson (1803-1882)
Dorothy McCune
ashleyw(at)gvtc.com
PostPosted: Mon Jul 06, 2009 8:41 am    Post subject: FIRST FLIGHT Reply with quote
Ron,
The air over the aileron is undistrubed even in the stall due to the wing
twist.
This link is to a video I made in my 601XL. Notice at 22 seconds the wing
root trailing edge is showing distrubance.
At 36 seconds, I was indicating approx 30 KIAS and fully stalled. The
airflow over the ailerons is not distrubed.
http://www.gvtc.com/~ashleyw/
The trim tab should work in either direction.
Floyd Wilkes
601XL O-200
bryanmmartin
PostPosted: Mon Jul 06, 2009 11:39 am    Post subject: FIRST FLIGHT Reply with quote
The only thing this will accomplish is to offset the neutral position
of the stick to the left. The only way to correct a heavy left wing is
to apply a counteracting force; either with stick force, a trim tab,
ballast weight or by adjusting the rigging of the wings.
ARCHIVE
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
Bryan Martin
do not archive.
GLJSOJ1
PostPosted: Mon Jul 06, 2009 7:07 pm    Post subject: Re: FIRST FLIGHT Reply with quote
thanks for all the suggestions guys and gals
To answer some questions, I have an O-200 with a Warp drive 3 blade prop It was set a 13.5 deg and tonight I backed it down to 12 deg. I am still only getting 2,000 static on the run up tonight, however now I can't hold with brakes to do a run up at 1,700.
Weight and balance. total weight is 818#. the nose is the heaviest by far and I can't remember the two mains, but I do believe the left wheel was heaver by about 15#.
I am planning on re visiting the aileron rigging before this weekend and try another test this weekend pending weather. I also have a EAA meeting tomorrow so I'll get more info there also.
I'll submit more information as I fly more.
Thanks again
Glenn
CHESAPEAKE VA
Ron Lendon
PostPosted: Tue Jul 07, 2009 3:45 am    Post subject: Re: FIRST FLIGHT Reply with quote
Congratulations Glen.
I am traveling from Nags Head back to Michigan and stayed in Chesapeake last night. We might have been on the Chesapeake Bay Bridge/Tunnel right about the time of your flight. It's almost like we were there with you Very Happy
Proud moments for you, fly safe.
Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
Davcoberly(at)wmconnect.c
PostPosted: Sun Jul 19, 2009 12:38 pm    Post subject: First Flight Reply with quote
Took my Corvair powered 601XL ( N601XZ ) for it's first flight today all went well just alittle over 39 more hrs of Phase I left Smile David Coberly 601XL / Corvair [quote][b]
larry(at)macsmachine.com
PostPosted: Sun Jul 19, 2009 1:30 pm    Post subject: First Flight Reply with quote
Congratulations David! You've achieved a significant milestone and the
adventure is just beginning.
Do fly safe
lwinger
PostPosted: Sun Jul 19, 2009 5:12 pm    Post subject: First Flight Reply with quote
What a great accomplishment!  Congratulations -- and keep the pireps coming.
Larry Winger
650/Corvair
Installing the canopy
Larry Winger
Tustin, CA
Plans building 601XL/650 with Corvair
Installing fuel system
www.mykitlog.com/lwinger
johnd
PostPosted: Mon Jul 20, 2009 6:06 am    Post subject: First Flight Reply with quote
Hi David,
Congrats on your first flight!!
Have a great time flying off your Phase I hours and may the weather gods be with you. They havent been for mine Smile
Fly Safe,
John Davis
N601JD
601XL/ Jab 3300
15 Hrs and counting...
Davcoberly(at)wmconnect.com (Davcoberly(at)wmconnect.com) wrote: [quote]Took my Corvair powered 601XL ( N601XZ ) for it's first flight today all went well just alittle over 39 more hrs of Phase I left Smile David Coberly 601XL / Corvair
href="http://www.matronics.com/Navigator?Zenith-List">http://www.matronics.com/Navigator?Zenith-List
