rlborger(at)mac.com Guest
				 Posted: Sat Jul 25, 2009 10:22 am    Post subject: Throttle fix |
				Gents,
 Don't know if any of you remember or not, but I kinked the throttle
 cable and had to come up with a suitable replacement.  I believe I
 have found a good working solution that should not have any further
 problem with kinking.
 Mind you, I am not recommending this solution to anyone else only
 pointing out what worked for me.  You are on your own for a solution
 to this problem should you kink your throttle cable.
 I've posted my solution on my build web site should you be interested.
 Unfortunately, the solution came with another setback.  In order to
 get the wire to exit the cable sheath, I had to disconnect the cable
 sheath end at the starboard carb mount.  As I was unscrewing the nut
 holding things, the sheath took the bit in its teeth and made a run
 for it flinging the nut off into the vicinity of Neverland or there
 'bouts.  Since this is a metric nut I don't happen to have a suitable
 replacement on hand.  A new nut will have to be ordered from
 Lockwood.  Always something.  No great rush as long as it's here
 sometime next week while I'm at Airventure.  With any luck, I can fix
 things next weekend.  Then I can get the engine going again and
 rebalance the carbs.
 Hope to see a lot of you folks at Airventure!
 Check six,
 Bob Borger
 Europa Kit #A221 N914XL, XS Mono, Intercooled 914, Airmaster C/S
 http://www.europaowners.org/N914XL
 Aircraft Flying!
 3705 Lynchburg Dr.
 Corinth, TX  76208
 Home:  940-497-2123
 Cel:  817-992-1117
