				 Posted: Thu Jul 23, 2009 10:13 pm    Post subject: Do you need to sand off all guide coat? |
				Even my fingers are getting confused with too many colors:
 60 minute hardener (yellow/brown)
 30 minute hardener (red)
 Q-cel
 Expancel
 Aeropoxy light
 JB weld KWIK
 Gray gelcoat
 White gelcoat
 Fiberglass
 Anyway I was thinking about trying out some flat black spray guide coat  purchased from Eastwood.
 Question is after you apply it and sand most of it off, the black will be left behind to show low spots, do I need to sand off black in low spots and fill, or can I fill over black painted spot? perhaps scuff sand with scotchbright?
 Thx.
 Ron Parigoris
 Visit -  www.EuropaOwners.org
				 Posted: Fri Jul 24, 2009 12:04 am    Post subject: Do you need to sand off all guide coat? |
				Hi! Ron
 I'm no paint specialist but.........so long as your guide coat is
 compatible with your intended primer/undercoat/gloss coat it shouldn't
 be necessry to remove it all, otherwise it negates the purpose of the
 guide coat.
 Bob Harrison G-PTAG
  	  | Quote: | 	 		  ----Original Message----
 Date: 24/07/2009 7:04
 Subj: Do you need to sand off all guide coat?
  ny.us>
 Stay safe online with Tiscali Security Centre  -  http://www.tiscali.co.uk/security
 __________________________________________________________________
		acrojim7534(at)YAHOO.COM Guest
				 Posted: Fri Jul 24, 2009 3:14 am    Post subject: Do you need to sand off all guide coat? |
				Ron
  You need to remove the paint. If you put filler over the paint, the "bond" will be filler to paint, instead of filler to filler.
  Jim Brown
 --- On Fri, 7/24/09, rparigoris <rparigor(at)suffolk.lib.ny.us> wrote:
 Subject: Do you need to sand off all guide coat?
 Date: Friday, July 24, 2009, 6:04 AM
  --> Europa-List message posted by: "rparigoris" <rparigor(at)suffolk.lib.ny.us (rparigor(at)suffolk.lib.ny.us)>
 Q-cel
 Expancel
 Aeropoxy light
 JB weld KWIK
 Gray gelcoat
 White gelcoat
 Fiberglass
 Thx.
 Ron Parigoris
 Visit -  tronics.com/Navigator?Europa-List" target=_blank>http://www.matronics.com========================
