		pt19(at)localnet.com Guest
				 Posted: Sun Aug 02, 2009 2:11 pm    Post subject: engine noise on radio |
				Having problems with background noise from  582 engine when transmitting.  Is there a mic that will reduce or eliminate this noise?
 Thanks,  Jack  [quote][b]
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Roger Lee
				 Posted: Sun Aug 02, 2009 10:01 pm    Post subject: Re: engine noise on radio |
				You can put a filter in line, remove any radio wires from other high energy out put and shield your radio wires.
  _________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Home 520-574-1080  TRY HOME FIRST
Cell 520-349-7056 |
		fredmessinger(at)gmail.co Guest
				 Posted: Mon Aug 03, 2009 3:53 am    Post subject: engine noise on radio |
				Hi Jack,
 I had that problem too in my trike for a while.   I had placed the output coax of my radio too close to the intercom system.   When I moved it 2-3 inches away, the interference stopped.
 Fred
  On Sun, Aug 2, 2009 at 6:10 PM,  <pt19(at)localnet.com (pt19(at)localnet.com)> wrote:
 Thanks,  Jack   	  | Quote: |
 ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
 tp://forums.matronics.com
  | 	  [b]
		Guy Buchanan
				 Posted: Mon Aug 03, 2009 9:21 am    Post subject: engine noise on radio |
				At 03:10 PM 8/2/2009, you wrote:
  	  | Quote: | 	 		  Having problems with background noise from  582 engine when
 If the noise is coming in through the mic, turn down the mic gain and
 talk loud. It sounds silly but it works really well to raise the
 signal / noise ratio. It's not my idea but an old trick from open
 cockpit days. Also you can buy larger foam muffs to go over the mic,
 however they basically do the same thing - mechanically reducing the
 mic gain so you have to talk louder.
 Guy Buchanan
 San Diego, CA
 K-IV 1200 / 582-C / Warp / 400 hrs. and counting
Deceased K-IV 1200
A glider pilot too. |
