herbgh(at)nctc.com Guest
Posted: Sun Aug 02, 2009 8:39 am Post subject: Leaking exhaust manifold |
On other engines, I have seen a warped flange on the exhaust tee
that can be trued up with a mill or belt sander...Herb
Posted: Sun Aug 02, 2009 8:54 am Post subject: Leaking exhaust manifold |
| Quote: | that can be trued up with a mill or belt sander...Herb
That reminds me.
I have truing bars for the aircooled and water cooled Rotax aircraft
engines.
Might not hurt to have a machine shop true the mating surface of the
manifold.
_________________ John Hauck
Titus, Alabama |
aoldman(at)xtra.co.nz Guest
Posted: Sun Aug 02, 2009 11:40 pm Post subject: Leaking exhaust manifold |
I found the best way to seal the exhaust was to loosen the head nuts before
doing up the exhaust bolts then retough the heads and barrels . This makes
sure the exhaust ports line up square with the exhaust manifold giving the
best seal.
Tony
Downunder
MK111c
503
