James Missler
Joined: 14 Jan 2006 Posts: 8 Location: Bellevue, Ohio
Posted: Sun Aug 02, 2009 5:25 pm Post subject: Engine Dipstick 2200 |
I recently started test flying my Kitfox 3 with Jabiru 2200 # 976 and Jrince 64-28 prop. Everything is going fine except that I can not easily remove the dipstick when hot. I like to moniter oil level after each flight but have to wait till it cools down or use a pliers which is difficult. I have removed about .030" from the thread outside diamater of the plastic cap and used a #16 thread file to cut them a little deeper with no results. I also put some grease on the threads with no improvement. Has anyone else had this problem and what did you do to correct it? Thanks for your help.Windows Live™: Keep your life in sync. Check it out. [quote][b]
_________________ Jim Missler, Kitfox 3, Jabiru 2200, Prince P Tip Prop 64-28, Just plane fun. Bellevue, Ohio |
plus2s
Posted: Sun Aug 02, 2009 5:51 pm Post subject: Engine Dipstick 2200 |
Don't do it up so tight - the alloy expands with the heat and tightens it
Keith
--- On Mon, 3/8/09, James Missler <misslerfarms(at)msn.com> wrote:
Subject: Engine Dipstick 2200
Received: Monday, 3 August, 2009, 1:24 PM
#yiv1857686610 .hmmessage P { margin:0px;padding:0px;} #yiv1857686610 { font-size:10pt;font-family:Verdana;} I recently started test flying my Kitfox 3 with Jabiru 2200 # 976 and Jrince 64-28 prop. Everything is going fine except that I can not easily remove the dipstick when hot. I like to moniter oil level after each flight but have to wait till it cools down or use a pliers which is difficult. I have removed about .030" from the thread outside diamater of the plastic cap and used a #16 thread file to cut them a little deeper with no results. I also put some grease on the threads with no improvement. Has anyone else had this problem and what did you do to correct it? Thanks for your help.
Windows Live™: Keep your life in sync. Check it out. | Quote: |
ist" target=_blank rel=nofollow>http://www.matronics.com/Navigator?JabiruEngine-List
=nofollow>http://forums.matronics.com
blank rel=nofollow>http://www.matronics.com/contribution
| [quote][b]
jetboy
Posted: Sun Aug 02, 2009 7:10 pm Post subject: Re: Engine Dipstick 2200 |
Everyone seems to have the same difficulty and it is not about it being over tight to start with but the threads hold firm when it is hot.
Best just to live with it as its hard to get a valid reading off a recently run engine or after adding oil for quite some time. On the other hand if you leave it a few days the oil from filter / cooler drains back increasing the reading on the stick above the actual qty. available.
Ralph
_________________ Ralph - CH701 / 2200a |
pj.ladd(at)btinternet.com Guest
Posted: Mon Aug 03, 2009 1:39 am Post subject: Engine Dipstick 2200 |
what did you do to correct it? >>
Dont do it! You wont get an accurate reading while the engine has just been run anyway.
Cheers
Pat
Lynn Matteson
Posted: Mon Aug 03, 2009 9:18 am Post subject: Engine Dipstick 2200 |
Hi Jim-
The first thing to do is not tighten it up so much. You'd be
surprised how little tightening needs to done on the dipstick. I
never worry too much about mine coming loose because my cowl will
prevent it from coming out completely, so I've experimented around
with leaving it looser and looser.
Lynn Matteson
Jabiru 2200, #2062, 720 hrs
Sensenich 62"x46" Wood prop
Soon to have Rotec TBI-40 injection
Status: working on TBI installation...very close to completion
On Aug 2, 2009, at 9:24 PM, James Missler wrote:
| Quote: | I recently started test flying my Kitfox 3 with Jabiru 2200 # 976
Windows Live™: Keep your life in sync. Check it out._-
============================================================ _-
contribution_-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
