instrument panel water jet cutting
rv8ch
PostPosted: Tue Apr 04, 2006 8:21 am    Post subject: instrument panel water jet cutting Reply with quote
Hi,
Anyone have some suggestions for instrument panel
water jet cutting? I've tried experimentalair.com
but I'm not getting any response. Perhaps I'm being
too impatient. Stein's focusing on complete panels,
as is affordable panels.
Thanks for any pointers.
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
Mickey Coggins
http://www.rv8.ch/
skytop(at)megsinet.net
PostPosted: Tue Apr 04, 2006 10:47 am    Post subject: instrument panel water jet cutting Reply with quote
Werner Berry of Pacific Panel uses CNC, but the end results are perfect
holes. Great service too.
http://www.sptpanel.com/
Tom Barnes -6 first flight two years today.
stevea(at)svpal.org
Any particular reason you want water jet cutting? NC (numerically
controlled) routing is also used to cut instrument panels. The 1/8 inch
diameter router bit used can not cut as tight a corner as a water jet,
so some filing may be required for tighter corners. Avionics panel
shops should be familiar with this. Other than that, the cut panel
should come out the same. The avionics shops I talked to use NC routers.
My panel is at an avionics shop (as I type this) to be cut, painted,
engraved and matte finish epoxy clear coated. Contact me off list if
you want to know my experience so far.
Steve
RV-6A
jpl(at)showpage.org
PostPosted: Tue Apr 04, 2006 11:23 am    Post subject: instrument panel water jet cutting Reply with quote
I think he was asking about water jet cutting as that's what's used
at experimentailair.com. This site has what appears to be pretty
reasonable prices for designing and cutting your panel, so I can see
the attraction.
-Joe
RV-6A. Well, I think I'm about halfway through the "V" so far Smile
inch
routers.
Steve
RV-6A
Rhonda(at)bpaengines.com
PostPosted: Tue Apr 04, 2006 11:59 am    Post subject: instrument panel water jet cutting Reply with quote
Experimental Air is owned by Ross Schlotthauer who built an RV-7. I
left him a voice mail and will be happy to pass on his phone number as
soon as I get the go ahead from him.
Rhonda
wgill10(at)comcast.net
PostPosted: Tue Apr 04, 2006 4:00 pm    Post subject: instrument panel water jet cutting Reply with quote
Mickey,
Experimentalair does great work, your patience will payoff.
A satisfied customer.
Bill
emrath(at)comcast.net
PostPosted: Wed Apr 05, 2006 5:46 pm    Post subject: instrument panel water jet cutting Reply with quote
There is a gentlemen in Nashville TN that cut mine for me. Lee Moore, who's
email is "Jet(at)south-tech.us" or call him at (615) 847-8226. He was very
helpful. I started with my own Turbo Cad file and he spiffed it up, cut a
piece of scrap for fit up and then we cut the real deal. I actually had him
make three pieces, a frame that will be permanently mounted in the RV and
then two panels, left and right, leaving a center cutout for my radios.
Very accurate cutting, with no metal burning as in a laser cut. He can
punch holes in 1.5" thick steel. It is worth a visit if you have not seen
this live.
Marty in Nashville TN, RV-6A panel mounting.
