Correction
naumuk(at)windstream.net
PostPosted: Tue Sep 08, 2009 2:44 pm    Post subject: Correction Reply with quote
All-
Eyeball vent OD is 1-3/4" Do you just tighten the hell out of the clamp on 2" vent tubing?
Bill Naumuk
Townville, Pa.
HDS N601MG/Corvair 95%
jerryvmd
PostPosted: Tue Sep 08, 2009 4:01 pm    Post subject: Correction Reply with quote
Bill,
If you unwind some of the wire from inside the scat tube away from the
outer hose, then cut it off, you can then tighten the outer sheath
without the wire getting in the way. This worked well on all my
fittings and the sheath is less likely to tear and is easier to get on
and off.
Jerry
Bill Naumuk wrote:
All-
Bill Naumuk
Townville, Pa.
