Gwayne
Posted: Tue Aug 18, 2009 1:47 pm Post subject: IO-540 C4B5 |
Anybody have any thoughts on this 250hp narrow deck engine for the -10 I am building.
Wayne
_________________ Wayne
RV 7 "eh?" 120 hrs
RV 10 fuse |
dmaib@me.com
Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
Posted: Tue Aug 18, 2009 2:03 pm Post subject: IO-540 C4B5 |
I have a C4B5 in my airplane. The engine came out of an Aztec, so had
the wrong engine mount flanges. I had to order new ones from
Lycoming. Other than that, it works great.
David Maib
40559
Flying
On Aug 18, 2009, at 5:47 PM, Gwayne wrote:
-10 I am building.
Wayne
Wayne
RV 7 "eh?" 120 hrs
RV 10 fuse
http://forums.matronics.com/viewtopic.php?p 58513#258513
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
tomflysalot
coop85(at)verizon.net Guest
Posted: Tue Aug 18, 2009 3:25 pm Post subject: IO-540 C4B5 |
I had a C4B5 on my Skybolt and it worked great! My understanding (limited
at best) is the only difference is the counterweights limiting the max RPM
10 2600 whereas the D4A5 can spin up to 2700 which is where the 10 extra hp
comes from, otherwise they are the same. I also had to swap out the
mounting ears as mine came from an Aztec, but that is not a big deal.
Marcus
timrvator(at)comcast.net Guest
Posted: Wed Aug 19, 2009 3:33 pm Post subject: IO-540 C4B5 |
According to the Lycoming IO-540 Parts Catalog (PC-215-1, June 1993),
the C4B5 and D4A5 use the same counterweights (LW-19227) and same
rollers (72797). Going through the parts catalog, I found that every
single part is identical except for some different options on engine
mounting brackets ("ears") and oil filler/dipstick. Lycoming tech
support ((at) OSH) confirmed this. They confirmed the C4B5 can safely run
at 2700 rpm just like the D4A5, producing the same horsepower, because
they are the same engine.
Tim Lewis -- HEF (Manassas, VA)
RV-6A N47TD -- 1060 hrs
RV-10 N31TD -- Painting done, final assembly -- OSH 2010 or bust
Marcus
dmaib@me.com
Posted: Wed Aug 19, 2009 4:52 pm Post subject: IO-540 C4B5 |
My engine shop in Minneapolis, (Bolduc) confirmed this, as well.
David Maib
40559
Flying
1993), the C4B5 and D4A5 use the same counterweights (LW-19227) and
same rollers (72797). Going through the parts catalog, I found
that every single part is identical except for some different
options on engine mounting brackets ("ears") and oil filler/
dipstick. Lycoming tech support ((at) OSH) confirmed this. They
confirmed the C4B5 can safely run at 2700 rpm just like the D4A5,
producing the same horsepower, because they are the same engine.
> (limited
> max RPM
> extra hp
> Marcus
> Do not archive
RV-10 #40559
jim(at)CombsFive.Com Guest
Posted: Wed Aug 19, 2009 7:19 pm Post subject: IO-540 C4B5 |
YES IT DOES! I have a C4B5 and I do have it set up for 2700 RPM. Only use it for a short period but what a ride! Changed out the left retard mag with a Lightspeed Plasma III. Had Airflow Performance overhaul the injector system. Changed the mounting ears as wellJim C40192 (N312F) Flying 100 hours in 9 monthsDo Not Archive--> RV10-List message posted by: Tim Lewis <timrvator(at)comcast.net>According to the Lycoming IO-540 Parts Catalog (PC-215-1, June 1993),the C4B5 and D4A5 use the same counterweights (LW-19227) and samerollers (72797). Going through the parts catalog, I found that everysingle part is identical except for some different options on enginemounting brackets ("ears") and oil filler/dipstick. Lycoming techsupport ((at) OSH) confirmed this. They confirmed the C4B5 can safely runat 2700 rpm just like the D4A5, producing the same horsepower, becausethey are the same engine.Tim--Tim Lewis -- HEF (Manassas, VA)RV-6A N47TD -- 1060 hrsRV-10 N31TD -- Painting done, final assembly -- OSH 2010 or bustMarcus Cooper wrote:> --> RV10-List message posted by: "Marcus Cooper" <coop85(at)verizon.net>>> I had a C4B5 on my Skybolt and it worked great! My understanding> (limited> at best) is the only difference is the counterweights limiting the max> RPM> 10 2600 whereas the D4A5 can spin up to 2700 which is where the 10 extra> hp> comes from, otherwise they are the same. I also had to swap out the> mounting ears as mine came from an Aztec, but that is not a big deal.>> Marcus> Do not archive>> --
