cpayne(at)joimail.com Guest
Posted: Fri Aug 07, 2009 2:23 am Post subject: More spark plugs |
Perhaps I should have used the word "impedance" rather than "resistance" in my last post. Regardless, due care need to be taken when using spiral-wrapped silcone wire and motorcycle plugs. They work great but pay attention to:
- Use 1/2" reach plugs only.
- Select Resistor type.
- Mid-range heat conduction rating.
- I prefer solid terminal rather than the threaded type cap that can work loose.
- Keep the gap under .020"
- Don't over torque.
Always buy a few extra since they are brittle and can be damaged by dropping or get a case of "wrench rash". I never clean them, just replace at annual. The built-in crush washer is only good for 1 tightening anyway. A good price is about $2.00 each in packs of 10, as found at internet stores.
Craig Payne
cpayne(at)joimail.com (cpayne(at)joimail.com)
