Phil.Perry(at)netapp.com Guest
Posted: Wed Sep 23, 2009 6:54 am Post subject: Heater Boxes / Firewall Sealer |
I installed my aluminum heater boxes and even held them into position with proseal – per the plans.
Now I’m having second thoughts for a couple of reasons.
<![if !supportLists]>1) <![endif]>They’re aluminum and should they melt, there is a great hole to blast a fire up the tunnel and over the fuel.
<![if !supportLists]>2) <![endif]>The proseal has a flashpoint of ~200 degrees.
I plan on popping these boxes off and replacing with stainless boxes.
Q) What material did you use to seal them? I could use Red RTV, but I’m thinking firewall sealer (brand?) is a better option.
I’m also thinking of installing a thermal barrier between the boxes and the firewall. Maybe just a bed of firewall sealer, or a box-sized square of thermal insulation.
Q) Anyone else do that?
Phil
dogsbark(at)comcast.net Guest
Posted: Wed Sep 23, 2009 7:22 am Post subject: Heater Boxes / Firewall Sealer |
Phil,
The stainless boxes I installed came with a small tube of sealer that was rated to 1,600 degrees. I think some RTV is rated to 600 degrees. Can't remember what firewall proseal is rated, but all of these are better than regular proseal.
Don't forget to install the two nutplates on the heater boxes for the cables before installation.
Sean Blair
COS
Phil; A couple of weeks ago we went through a thread on the benefits of SS. I mentioned for the exact reason you covered that having SS is a good investment.
To save you the time- [url=http://www.planeinnovations.com/new%20heater.htm. ]http://www.planeinnovations.com/new%20heater.htm. [/url] The heater bypass comes with a seal so you don’t need to worry about RTV.
I have a pair and it's a great product!
Pascal
Sent: Wednesday, September 23, 2009 7:53 AM
Subject: Heater Boxes / Firewall Sealer
1) They’re aluminum and should they melt, there is a great hole to blast a fire up the tunnel and over the fuel.
2) The proseal has a flashpoint of ~200 degrees.
Phil
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Wed Sep 23, 2009 7:25 am Post subject: Heater Boxes / Firewall Sealer |
I just used the sealant that comes with the stainless parts from plane innovations.
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
nukeflyboy
Joined: 05 Jan 2008 Posts: 162 Location: Granbury, TX
Posted: Wed Sep 23, 2009 8:12 am Post subject: Re: Heater Boxes / Firewall Sealer |
I used a thick (1/8 in) silicone gasket under the heater box. This idea came from Tim (I think) as an unverified way to minimize heat transfer into the tunnel. Sounded like a good idea.
Since the sealant is not part of the fire barrier per se, I don't think it matters a lot. High temp RTV should work fine.
_________________ Dave Moore
RV-6 built and sold
RV-10 built and flying |
Posted: Wed Sep 23, 2009 8:43 am Post subject: Heater Boxes / Firewall Sealer |
Mine came with the attachments, I think Paul updated them. Call Paul at Plane innovations and ask him.
From: dogsbark(at)comcast.net (dogsbark(at)comcast.net)
Sent: Wednesday, September 23, 2009 8:19 AM
Subject: Re: Heater Boxes / Firewall Sealer
Phil,
Sean Blair
COS
AirMike
Posted: Wed Sep 23, 2009 8:26 pm Post subject: Heater Boxes / Firewall Sealer |
Another vote here for Paul at:
http://www.planeinnovations.com/new%20wheelpant.htm
Paul is great and VERY helpful. I consider the heater valves a must option
_________________ See you OSH '18
Q/B - sold. |
Posted: Wed Sep 23, 2009 8:50 pm Post subject: Heater Boxes / Firewall Sealer |
Have these too! I know the manufacturer of these personally and he makes
quality products. Think there was a hinge cover in development, waiting for
my order to arrive but I think I'll be equally happy with that product as
well.
Pascal
Sent: Wednesday, September 23, 2009 9:26 PM
