sarg314(at)gmail.com Guest
Posted: Mon Aug 03, 2009 9:20 am Post subject: Time for a new PC 680 ? |
I have a PC-680 that I bought 2 or 3 years ago. I used it to test my electrical system while I was wiring the plane. I've recharged it with a motorcycle battery charger. It spent 99% of it's time doing nothing. Never had much of a demand place on it. Still seems to hold a charge well. My engine start is going to be in September, probably.Â
Should I replace this battery before I fly? It would seem prudent, though I note they've gone up in price about 30% since I bought this one.
Tom Sargent
Posted: Mon Aug 03, 2009 10:18 am Post subject: Time for a new PC 680 ? |
I bought 2 PC680s a couple of years ago. Mainly did nothing but
notably, they were left in various stages of discharge for some period.
One just lost a cell. I'm still using both of them for avionics work
and keeping them charges but I will be swapping both out when I go
flying (next year?).
thomas sargent wrote:
| Quote: | I have a PC-680 that I bought 2 or 3 years ago. I used it to test my
Tom Sargent
frank.hinde(at)hp.com Guest
Posted: Mon Aug 03, 2009 10:20 am Post subject: Time for a new PC 680 ? |
If you have kept it on a smart charger and you are electrically dependant..then no do not replace it..It will be just fine.
If you have charged it occasionally but your running magnetoes and a mechacnical fuel pump...then once again it will be fine.
If you Have electronic ignitions and electric fuel pumps (and have not kept it regularly smart charged) , but it cranks over the engine then do all your phase one (day VFR) flying and consider replacing then....Before you do long cross country flying where you might need the full capacity of the battery to get you to a safe spot.
if it won't start the engine..well the choice is obvious.
Frank
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of thomas sargent
Sent: Monday, August 03, 2009 9:52 AM
Subject: Time for a new PC 680 ?
Tom Sargent
ist">http://www.matronics.com/Navigator?AeroElectric-List
ics.com
.matronics.com/contribution
thorps18(at)gmail.com Guest
Posted: Mon Aug 03, 2009 10:21 am Post subject: Time for a new PC 680 ? |
I would replace it, but if you have a magneto, you could probably get by. I had one of these in my motorcycle for 6 years before it needed replacing. IIRC, Mr. Nuckolls recommends changing every two years, but this may be for dual electronic ignition aircraft.
On Mon, Aug 3, 2009 at 9:52 AM, thomas sargent <sarg314(at)gmail.com (sarg314(at)gmail.com)> wrote:
[quote] I have a PC-680 that I bought 2 or 3 years ago. I used it to test my electrical system while I was wiring the plane. I've recharged it with a motorcycle battery charger. It spent 99% of it's time doing nothing. Never had much of a demand place on it. Still seems to hold a charge well. My engine start is going to be in September, probably.
Tom Sargent
tp://forums.matronics.com
| [b]
longg(at)pjm.com Guest
Posted: Tue Aug 04, 2009 5:59 am Post subject: Time for a new PC 680 ? |
Speaking of charging the 680. Do I really need one of those hyped up fancy chargers all the dealers sell for double deep-reduction, super reserve, cranks like a wild monkey charging? Sounds like a bunch of marketing to get to 13.2 volts. I’ve got a Walmart job that seems to do the same thing.
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Byron Janzen
Sent: Monday, August 03, 2009 2:15 PM
Subject: Re: Time for a new PC 680 ?
Tom Sargent | Quote: | | ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-Listtp://forums.matronics.com_blank">http://www.matronics.com/contribution |
0123456789 | Quote: | | ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List | 0 | Quote: | | ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List | 1 | Quote: | | ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List | 2 | Quote: | | ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List | 3 | Quote: | | ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List | 4 | Quote: | | ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List | 5
Posted: Tue Aug 04, 2009 6:41 am Post subject: Time for a new PC 680 ? |
You are now squarely facing the question that will
confront you for the entire time that you own this
airplane. What are YOUR conditions for continued
airworthiness? What are YOUR plans for monitoring
battery suitability to task? The decision to fly
or replace the battery today is no different than
the decisions to be made in years hence.
Even if it starts the engine you need to know more.
Hook a car headlamp and voltmeter to your fully
charged battery and monitor the time to take the
battery down to 10.5 volts. Is that enough time
to give you confidence in this battery's performance
for ANY flight?
There are thousands of worry-words exchanged on
the 'net every day about, "should I our shouldn't
I replace this battery?" Lord Kelvin was credited
with saying . . .
"When you cannot express it in numbers, your
knowledge is of a meager and unsatisfactory
kind."
So while preparing for first flight, I'll suggest
it is prudent to also prepare for responsible and
confident operation of your airplane. All the worry-
words exchanged without the benefit of data are
essentially useless. Figure out a practical way to
"get the numbers". Then you can tell US whether
or not the battery needs replacing.
( -Thomas Paine 1776- )
Posted: Tue Aug 04, 2009 6:46 am Post subject: Time for a new PC 680 ? |
At 08:55 AM 8/4/2009, you wrote:
| Quote: | Speaking of charging the 680. Do I really need one of those hyped up
marketing to get to 13.2 volts. I've got a Walmart job that seems to
do the same thing.
Yes, YES, YEEEESS! What "walmart" device do you
have? Know that one of the least expensive devices
I've purchased from Walmart was the Schumacher
1562 series devices for under $20 and is one of
the smartest chargers you can buy. There is no
longer any excuse for doing it right.
Bob Collins
Joined: 11 Mar 2006 Posts: 470 Location: St. Paul, Minnesota
Posted: Tue Aug 04, 2009 8:18 am Post subject: Time for a new PC 680 ? |
I need this clarified. HE asks if he needs one of those hyped up chargers.
The response is "yes yes yes" but then it sounds like the answer is "no no
no"... That the Walmart charger is good enough.
Do I have that right?
_________________ Bob Collins
St. Paul, Minn.
Letters from Flyover Country
http://rvnewsletter.blogspot.com/ |
Posted: Tue Aug 04, 2009 8:50 am Post subject: Time for a new PC 680 ? |
At 09:45 AM 8/4/2009, you wrote:
<nuckolls.bob(at)aeroelectric.com>
>bunch of marketing to get to 13.2 volts. I've got a Walmart job
I've purchased from Walmart was one of the Schumacher
1562 series device for under $20 and is one of
longer any excuse for NOT doing it right.
Got it right this time . . .
bwolf1(at)tds.net Guest
Posted: Tue Aug 04, 2009 8:58 am Post subject: Time for a new PC 680 ? |
I think Bob is saying, "There is no longer an excuse for NOT doing it right". Buy the Walmart charger.
Brooke
On Aug 4, 2009, at 12:15 PM, Bob Collins wrote:
[quote]--> AeroElectric-List message posted by: "Bob Collins" <bcollinsrv7a(at)comcast.net (bcollinsrv7a(at)comcast.net)>
Posted: Tue Aug 04, 2009 9:09 am Post subject: Time for a new PC 680 ? |
..since I'm looking through the archives right now, I'll take a crack
at it...
Yes, you do want and need a good 'smart' charger. A good smart charger
can be had a good price where ever stuff is sold, like Walmart. But
presumably there's junk out there too. And perhaps more importantly,
some smart chargers that are better than others.
So I'm going smart shopping....
I believe Bob has documented the specific performance we should look for
and I remember a graph of a good performing charger. I'm looking for it
now.
Posted: Tue Aug 04, 2009 9:15 am Post subject: Time for a new PC 680 ? |
Here's a link with several embedded links on subject
http://www.aeroelectric.com/articles/Batteries/Multiple_Battery_Myths_A.pdf
here's the chart:
http://tinyurl.com/553kmu
Posted: Tue Aug 04, 2009 9:19 am Post subject: Time for a new PC 680 ? |
Thanks Bob,
Yup, this one looks like mine. Schumacher SEM-1562A 1.5 Amp Slow Charge
Battery Companion
$25 - $30 on Amazon.
Glenn
pwmac(at)sisna.com Guest
Posted: Tue Aug 04, 2009 10:54 am Post subject: Time for a new PC 680 ? |
At 11:16 AM 8/4/2009, you wrote:
Thanks Bob,
Battery Companion
Glenn
And $18.xx at any Walmart with no shipping.
BTW, don't mislead the newbes. The subject is a "battery maintainer"
not a smart charger.
PW
dewittw(at)earthlink.net Guest
Posted: Wed Aug 05, 2009 6:46 am Post subject: Time for a new PC 680 ? |
Bob, I'm confused. Have you seen the August issue of Kitplanes and the article titled, "Are All Battery Chargers Alike?"?
Bob Fritz, who wrote the article, says the following:
"Last month we went through battery basics and saw that different requirements translate into different hardware. We’d been trying to find an approach to this subject for a couple of months when we were contacted by Bill Woods of VDC Electronics with an offer to assist in a piece on battery chargers and how they relate to aviation batteries. He was enthusiastic about a new charger the company had developed specifically for aviation and wanted to tell us about it.
"Sensing an opportunity for some new information, we continued the conversation. For the sake of objectivity we also contacted representatives at Concord and Odyssey, and then spent the day at a Teledyne Battery 101 class. Teledyne is the maker of Gill batteries. It soon became apparent that this was really two stories, one about batteries and another about battery chargers."
"Number six (a 12248-AA-S3, Dee) is a desulfating charger designed specifically for Odyssey 12-volt batteries...."
"Given the results (see the chart), would I recommend the units from VDC? I’d have to say yes, partly in light of the dismal results displayed by those chargers obtained at the auto parts store, and partly because of knowledge gained from a broad range of sources....
"Another factor in my thumbs up to the BatteryMINDer from VDC is that it’s the only charger I’ve seen that included a third wire with a ring lug. Said lug sends a temperature reading back to the black box and adjusts the power going to the battery according to the temperature of the battery. The ideal output of 13.1 volts is valid for a battery temperature of 77° F (25° C). Let the battery temp go above 125° F (52° C), and serious damage will be done. So when the battery goes above that 25° C, the sensor sends a signal that throttles back the output 28 millivolts per degree C. "
And under a photo of the five chargers he tested is the following caption:
Five chargers and four levels of performance. Note also that the two chargers on the upper right are from BatteryMINDer. One is labeled is the 12248-AA-S3 for “Odyssey type” batteries, and the other is the S2, for conventional flooded-cell batteries. These chargers are designed for specific applications and, although they will work on, say, your car, for the best battery life the charger should match. After checking with Marc Cook, Editor of Kitplanes, he made it clear we should only consider the 12248-AA-S3 charger for our Eggenfellner E6 3.6L, electrically dependent engine. That costs $189.95 from BatteryMINDers or VDC. What are your thoughts?
Also, we are not clear how we would attached this charger to our dual Odyssey 680 batteries. Must we charge each one separately since apparently there is only one temperature sensing lead? And if we charged them together, would this charger handle them each correctly since one could be a year older than the other if we follow your suggestion of replacing one battery each year?
Dee
DeWitt (Dee) Whittington
406 N Mulberry St
Richmond, VA 23220-3320
(804) 358-4333 phone and fax
SKYPE: hilltopkid
dee.whittington(at)gmail.com [quote][b]
Posted: Wed Aug 05, 2009 7:50 am Post subject: Time for a new PC 680 ? |
OK I am coming up on 3 years with my original Odyssey 680, I am completely electrically dependant..Electronic ignitions, Fuel pumps (I don't have a mechanical fuel pump) and I fly in IMC..I have a single battery and a backup SD8 alternator.
I will probably do a load test on the Odyssey this year but if it gives me decent range on min power then its not getting changed.
it spends almost all of its life on a smart charger.
Frank RV7
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of DeWitt Whittington
Sent: Wednesday, August 05, 2009 7:37 AM
Dee
406 N Mulberry St
SKYPE: hilltopkid
ics.com
mrspudandcompany(at)veriz Guest
Posted: Wed Aug 05, 2009 8:26 am Post subject: Time for a new PC 680 ? |
| Quote: | | There may be some very minor advantage to this super intelligent temperature monitoring charger but... Think of where your battery resides most of the time. It is in your airplane, enduring wide temperature swings, and tied to your electrical system. Do you suppose that there is this much monitoring of the temp and the input and output currents to your battery, while in your plane?? I think NOT, in about 99% of the aircraft. The little Schumacher battery charger / maintainer is much more gentle than any aircraft electrical system when connected to your battery. If you are going to spend $185 for a charger then maybe you want to look into better control and monitoring of the battery in the aircraft. Proper battery maintenance and regular interval load testing is always necessary, especially in an all electric aircraft. You may get a slitely longer interval between battery replacements, by investing in a "super gee whizz whow" charger, but is it worth it? Roger | [b]
Posted: Wed Aug 05, 2009 9:19 am Post subject: Time for a new PC 680 ? |
This, about Batteryminder, is interesting too:
http://www.vansairforce.com/community/showthread.php?t=41000
On Wed, Aug 5, 2009 at 9:23 AM, Roger <mrspudandcompany(at)verizon.net (mrspudandcompany(at)verizon.net)> wrote:
[quote] | Quote: |
| Quote: | There may be some very minor advantage to this super intelligent temperature monitoring charger but... Think of where your battery resides most of the time.
Roger |
| | Quote: |
Posted: Wed Aug 05, 2009 11:57 am Post subject: Time for a new PC 680 ? |
"Last month we went through battery basics and saw that different requirements translate into different hardware. | <snip>
| Quote: | | Quote: |
temp
maintainer
electric aircraft.
ABSOLUTELY! It's interesting to source the constellation of "requirements"
tossed about with so much allusion to practical significance. This
"Odyssey versus the charger world" battle has been raging for some years.
Arguments have bounced around like ping-pong balls in box rolling
down hill.
I have yet to see the results of any repeatable experiments
that demonstrate a positive return on investment for having
$purchased$ any "super-charger" combined with the $time$ needed
to apply it to practical management of a battery in an airplane
of any size but in particular, an RV8.
I'm working on a IR&D project for a new lead acid battery that
shows great promise for increased performance, lighter weight
and longer life. However, this isn't going to hit the market
as an inexpensive battery. Quite the contrary. This is why
we're mulling over ideas for optimized maintenance tools to
built right into the battery itself. The formula that evaluates
return on investment has a lot of variables that are themselves
somewhat ethereal. It's not easy.
In the mean time, the infomercials are in constant
competition for your attention, time and money.
Bob . . . [quote][b]
Posted: Sun Aug 09, 2009 7:10 pm Post subject: Time for a new PC 680 ? |
At 12:11 PM 8/4/2009, you wrote:
Just finished unloading the car after returning
from our trip to Colorado Springs. Look back over the
past posts . . .
Understand that few alternative chargers will produce
recharge curves identical to that cited above. They've
got a few things in common.
Relatively constant charge to a top-off level on the
order of 14.5 to 15.0 volts.
Sustained operation at the top-off level until recharge
current drops below some arbitrary but low level on the
order of 100 mA . . . or perhaps simply based on time
like 2 hrs in top-off mode. It's not critical.
After that, output voltage goes down to some value just
above 13.0 volts indefinitely.
The Shumacher 1562 series devices have been tested
and found to be an exemplary value from Walmart
at about $20. A number of devices from Harbor Freight
have been looked and some were found inadequate to
the protocols cited above. The Battery Tender/Battery Minder
products are also good. But there are dozens of others
and I've not tested but a very few. Make it easy on yourself
Go get the Schumacher device (or any Schumacher smart product)
from Walmart.
