jindoguy(at)gmail.com Guest
Posted: Wed Apr 05, 2006 4:51 am Post subject: Adventures in flutter |
As I mentioned in an earlier post, I encounered flutter in the left aileron
at about 75 mph on my fifth flight in my Mark III. Although I have tried to
maintain good airspeed control to stay out of the flutter regime, it
happened twice more, in both ailerons. After the last ime, I grounded the
aircraft until I could get the counter balances installed. I was doing a
general condition inspection pior to the installation and found that each
blade of the Warp Drive three blade prop had a divot in the forward surface
that aligned quite nicely with the left flap bell crank. The paint on the
aft most point of the bell crank was missing, too. That afternoon I ordered
plans from the factory and over the days I waited for them to arrive I began
to wonder if this was becoming a chicken and egg mystery. Did the prop hit
the flap bell crank and with that rythmic beat excite the aileron into
flutter, or did the flutter cause the bell crank to contact the prop? There
appears to be adequate clearance, about an inch, between the bell crank and
the prop when checking it statically, however, checking the plans shows that
the bell cranks have been installed improperly, and are rotated about 15
degrees past vertical toward the rear.
More checking of the plans revealed that the engine mount is built upside
down in a cross between the 582 and 618 design. Rather than a single motor
mount plate that bolts to the engine and the engine's vibration isolaters,
it is composed of two plates, front and rear, carrying the isolaters atop
which are two 2" square tube risers, running fore and aft. Studs going
through the risers attach the engine to the mount plates. There are no
inserts or spacers to keep the studs from squeezing the tubes (architectural
tubing that has no radius in the corners, I might add), but a square, 1/4"
thick spacer serves to spread the load of the engine to the vertical walls
of the tubes. Clear as mud, right?
So, with that back ground into the mechanics of the engine and ailerons and
how they may, or may not, be interacting to create the flutter in the
ailerons, here's my question to the group. I can replace the blades in the
Warp Drive prop and go back to a 66" prop, it's now 68", or I can replace it
entirely with an IVO or a GSC. The IVO has the option of adding the in
flight adjustable hub at a later date. If you are flying one of these props,
I'd like to hear your recommendation and insight.
Rick Girard
"Pining for a home on the Range"
| - The Matronics Kolb-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
John Jung
Joined: 10 Jan 2006 Posts: 108 Location: Surprise, AZ, USA
Posted: Wed Apr 05, 2006 6:17 am Post subject: Re: Adventures in flutter |
jindoguy(at)gmail.com wrote: | So, with that back ground into the mechanics of the engine and ailerons and how they may, or may not, be interacting to create the flutter in the ailerons, here's my question to the group. I can replace the blades in the Warp Drive prop and go back to a 66" prop, it's now 68", or I can replace it entirely with an IVO or a GSC. The IVO has the option of adding the in flight adjustable hub at a later date. If you are flying one of these props, I'd like to hear your recommendation and insight.
Rick Girard |
Rick,
Unless the Warp is contacting the bellcranks within an inch of the tips, or has too much damage, I would not change props. It appears to me that the prop is not the problem, and by changing the prop, you may make the problem worse or at least fail to fix it. I suggest that you fix the bellcranks, if you can, as well as the counterweights. I couldn't tell from your description if there is or isn't a problem with the motor mount. It sound like some that I have seen on Mark III's, and unless the bolts are not keeping some tension, there may be no problem. You might check that the non-standard motormount didn't move the engine farther forward.
_________________ John Jung
Firestar II N6163J
Surprise, AZ |
Posted: Wed Apr 05, 2006 7:49 am Post subject: Adventures in flutter |
John, I guess I left it without saying that I fixed the problem with the
bell crank installation before I did anything else. As for the prop, it's
beyond my comfort zone to fly with a prop that has visible damage, so the
question to Mark III, 582 flyers remains, which do you prefer, the Warp
drive, Ivo, or the GSC prop?
> Rick Girard
Rick,
keeping soom tension, there may be no problem.
John Jung
Firestar II N6163J
Surprise, AZ
http://forums.matronics.com/viewtopic.php?p=3D26583#26583
Rick Girard
Richard Pike
Joined: 09 Jan 2006 Posts: 1669 Location: Blountville, Tennessee
Posted: Wed Apr 05, 2006 7:50 am Post subject: Adventures in flutter |
I am at a loss to understand why you need the 2" risers - I am running a
582 with a 68" Ivo & B box, and all I needed was a 1 3/8" spacer to get
enough clearance.
Also, I have a 2.5 inch spacer between the Rotax prop flange and the
prop, which gives me 5" of clearance between the flap bellcrank and the
prop.
I am of the opinion that 1" of clearance between the prop blade and the
bellcrank is not nearly enough, even considering the stiffness of the
Warp Drive. A good dose of turbulence and a bit of gyroscopic precession
of the prop, or one of my landings would be all it would take to get rid
of all of that 1" of clearance, plus a bit more.
I have seen the 2" square tube risers that you describe, and they strike
me as a poor design. I obtained a 6" length of 1.25 aluminum dowel and
took it to a machine shop and had it cut on a lathe to 1&3/8" lengths,
and then bored on the lathe so the bolts would go straight down the
middle. That gives a solid block of aluminum between the Lord mounts and
the engine motor mounts, and is probably sufficient for anything you
could sit up there, much less a lowly 582.
There are some views of it on the bottom of this page here:
http://www.bcchapel.org/pages/0003/pg2.htm
It is possible that there is an interaction between the flaps, ailerons
and the prop. With the prop passing so closely to the flap torque rod,
which is attached to the aileron torque rod, it is not impossible that
you could get a harmonic. Which is yet another reason to get an
extension and move the prop back another 2.5 inches away from the wing.
Richard Pike
MKIII N420P (420ldPoops)
Rick Girard
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
ElleryWeld(at)aol.com Guest
Posted: Wed Apr 05, 2006 4:38 pm Post subject: Adventures in flutter |
Rick
if you install an IVO prop you will get a 2 3/4 inch spacer that will help
you with your problem with the prop running close to the linkeage I run an IVO
and I like it very much
Ellery in Maine
Earl Zimmerman
Joined: 13 Jan 2006 Posts: 35 Location: Elizabethtown, PA
Posted: Wed Apr 05, 2006 6:07 pm Post subject: Adventures in flutter |
ElleryWeld(at)aol.com wrote:
Quote: |
Rick
Ellery in Maine
I agree with Ellery. I would go with a two blade 68" IVO. ~ Earl
by0ung(at)brigham.net Guest
Posted: Thu Apr 06, 2006 9:11 am Post subject: Adventures in flutter |
Rick Girard
Quote: | >>>>>>>>>>>>>>>>>>>>>>>>>>>
In my opinion.
At this point I am not sure I would take apart the bellclranks,,,, what I
think I would do is install a prop spacer, 3 inch or so. the prop
spacer would eliminate the interference fit and also give you a boost in
performance. By putting the prop further from the disturbed air. It will
also make it a bit quieter. I would then install the counter weights in the
ailerons.
I would not use the ivo prop as it is more flexable and would cause the
prop strike problem to be worse. Also the flight adjustable hub is best
served in an aircraft that flies much faster than the kolb will go. As to
the 66 or 68 inch prop it would depend on the engine and gear ratio. With
the speeds that the kolbs fly the 68 would be better if your engine and gear
ratio will support it.
Boyd Young
Denny Rowe
Joined: 10 Jan 2006 Posts: 89 Location: Leechburg, PA
Posted: Thu Apr 06, 2006 5:57 pm Post subject: Adventures in flutter |
I agree on all points with Boyd.
Denny Rowe,
Mk-3, 68 inch Powerfin
