		zenith-list(at)steensland Guest
				 Posted: Tue Aug 11, 2009 9:51 am    Post subject: elevator trim tab inspection plate |
				Folks,
 Did you just rivet the plate on, or did you "upgrade" to nut plates? I
 worry about ever having to drill those rivets out incase something
 happens to the servo or if I want to CorrsionX in the inside of my tail.
 Lee Steensland
 601XL/Corvair (7637L reserved) Kit/Scratch builder 10.0% complete!
  |  | - The Matronics Zenith601-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		corvair.flier(at)gmail.co Guest
				 Posted: Tue Aug 11, 2009 10:18 am    Post subject: elevator trim tab inspection plate |
				Hey Lee,
 I have been thinking about the same thing. So I have decided to go with nut plates and machine screws. Not that I am opposed to rivets, but wanted to make it easier to access in case of an issue.
  On Tue, Aug 11, 2009 at 1:50 PM, Lee Steensland <zenith-list(at)steensland.net (zenith-list(at)steensland.net)> wrote:
  	  | Quote: | 	 		   --> Zenith601-List message posted by: Lee Steensland <zenith-list(at)steensland.net (zenith-list(at)steensland.net)>
  Folks,
  Did you just rivet the plate on, or did you "upgrade" to nut plates? I worry about ever having to drill those rivets out incase something happens to the servo or if I want to CorrsionX in the inside of my tail.
  Lee Steensland
  st" target="_blank">http://www.matronics.com/Navigator?Zenith601-List
  http://forums.matronics.com
  le, List Admin.
 Garry Williams
 EAA - 1031 - http://corvair-flier.com/
 Corvair Powered - 601XL Scratch Builder
 Edinburg, VA
		pdn8r(at)yahoo.com Guest
				 Posted: Tue Aug 11, 2009 10:22 am    Post subject: elevator trim tab inspection plate |
				I'm using nutplates - just in case.
 Bill Pagan EAA Tech Counselor #4395
 601XL QBK/Corvair/N565BW (RES)
 --- On Tue, 8/11/09, Lee Steensland <zenith-list(at)steensland.net> wrote:
 From: Lee Steensland <zenith-list(at)steensland.net>
 Subject: elevator trim tab inspection plate
 Date: Tuesday, August 11, 2009, 1:50 PM
 Folks,
 -- Lee Steensland
 601XL/Corvair (otoshare, and much much onics.com/Navigator?Zenith601-List" target=_blank>http://www.matronics.cop;                   -Matt Draronics.com/contribution" =======
		psm(at)att.net Guest
				 Posted: Tue Aug 11, 2009 10:35 am    Post subject: elevator trim tab inspection plate |
				I riveted the plate in question, and many other places as well.  I
 still used nutplates and screws in places which certainly need access
 for inspection such as the aileron bellcrank.
 Drilling out rivets is very easy if you do it properly.  I start with
 a number 40 drill (the same one I start drilling rivet holes with)
 and drill the center of the rivet down just a little way.  Then I use
 a number 30 followed by a number 20 if needed until the head of the
 rivet pops off.  Some times this also removes the rest of the rivet
 and some times it takes a little work with a punch to remove the
 remaining parts.
 After doing this at least 200 times on my airplane I feel it is a
 straight forward and easy process to complete with no damage to the
 parts being held by the rivet.
 Paul
 XL waiting for engineering changes
 At 10:50 AM 8/11/2009, you wrote:
  	  | Quote: | 	 		  Folks,
