mprather(at)spro.net Guest
				 Posted: Thu Aug 13, 2009 6:55 am    Post subject: AeroElectric-List Digest: 12 Msgs -       08/12/09 |
				Any chance of a bad ground or some other noise working its way into the
 system?  It doesn't sound like sloshing error, and maybe not a sensor
 problem - though I don't know enough to rule that out.  It also doesn't
 sound like a calibration problem.  I would stop calibrating as I don't
 think it will fix the problem (until you fix the real problem).
 Matt-
  	  | Quote: | 	 		   Bill and Matt,
  I, too, visually check the fuel quantity as always, but it is nice to have
  some reasonably accurate indication of fuel quantity in the cockpit while
  flying.  My AF-3400EM records fuel flow, quantity used/remaining,  etc.,
  and
  it is also a reference tool for decision making.
  The Princeton sensors for the RV are very short and they fit  vertically
  at
  the wing root.  So, the sloshing error should be  minimized as compared to
  the Lancair version.  There is also a dampening  built into the sensor
  circuit to help eliminate the sloshing error.  So,  the sloshing error is
  largely
  mitigated.  The problem I've had is getting  the Princeton sensors to send
  consistent signals to the AF-3400 engine  monitor.  I calibrated the
  sensors
  seven times by draining the tanks and  adding measured 2 gallon increments
  to each tank.  After each  addition, I let the fuel settle down before
  taking the reading being sent  to the engine monitor and entering the
  reading
  into the engine monitor  non-volatile memory.  Above about 12 gallons, all
  readings are the same  because the fuel level is above the top of the
  sensor.
  The problem I'm having is that the sensor is sending signals to the EM
  that
   are up and down the scale.  The EM is simply displaying the quantity it
  recognizes in relation to the calibration entries.  I am convinced the
  problem lies with the Princeton sensors.  Yes, I've talked to the
  manufacturer
  and he says, "It should work.  Try calibrating again."
  The fuel sensors are mounted in the wing root and, thus, are difficult to
  get to for removal and replacement.  So, I'm not excited about pulling out
  the current ones and replacing them - too much Pro-Seal.
  I'm going to burn the tanks down some more and dip check the tanks and see
  how the readings compare.
  Stan Sutterfield
  <I have the Princeton capacitance sensors in my Lancair.  I have  not yet
  calbrated them, but I would be very shocked if the fuel slosh  didn=92t
  cause a
  lot of errors.  The sensors are about 6 feet long  and must be no more
  than
  20 degrees off of horizontal.  Fuel  sloshing would move a great distance
  up
  and down the tubes.  I have  them in there because FAA says I need a fuel
  guage.  I will check the  level visually before each flight and refill
  when I
  should be at =BC to  =BD tank.  Reguardless of what the fuel gage says!>
  <Seems like sloshing can be dealt with either/both mechanically  or/and
  electrically:
  - A restriction or a baffle can be used to slow  the flow of fuel into and
  out of the tube(s).  I'd be slightly surprised  if the manufacturer didn't
  include this.
  - A low pass filter can be  used to average and damp the display in
  response to the raw input from the  sensor.  Again, I'd be slightly
  surprised if the manufacturer didn't  include this.>
  |  | - The Matronics AeroElectric-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
