aerosport1
Posted: Sat Aug 15, 2009 6:05 am Post subject: Alternator belt alignment |
I was putting on my alternator today and find that the belt is misaligned
by about 1/3 of the belt width to the belt groove on the engine. I have a Aerosport engine and the stock PLane Power alternator has any one else seen this problem? Or is this standard and leave it alone. I would think they need to be perfectly
aligned.
Geoff
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
greghale
Joined: 10 Jan 2007 Posts: 91 Location: Tulsa, Oklahoma
Posted: Sat Aug 15, 2009 6:23 am Post subject: Re: Alternator belt alignment |
My Plane Power alternator pulley did not align with th ring gear pulley groove. I swapped ends with the alternator bracket and that corrected the problem. I did however have to make new spacers on the bracket to hold the alternator in position. I am using the dual groove ring gear for the air conditioning compressor.
Greg...
_________________ Greg Hale rv10 -- N210KH
www.nwacaptain.com |
aerosport1
Posted: Sat Aug 15, 2009 10:05 am Post subject: Alternator belt alignment |
Mystery is solved. I some how had turned the ring gear pulley groove plate
one stud off and was just hand tighten it. Once I got it holes in the
correct alignment everything was good. All is good and prop is on.
Thanks Geoff
Geoff Combs
President
Aerosport Modeling & Design
8090 Howe Industrial Parkway
Canal Winchester, Ohio 43110
614-834-5227p
614-834-5230f
www.aerosportmodeling.com
RV-10 QB N829GW
Flying 500 hrs
40033 |
