		Dick Maddux
				 Posted: Sun Sep 06, 2009 4:52 am    Post subject: bubbles under the skin |
				You know, it's always something! Yesterday I noticed some very large and small bubbles under the skin of my aircraft located over my right fuel tank. Some of them were about 4 inches in diameter. These protruded about 1/2 inch above the surface. Now my question is, "what caused that ?" The only thing I can think of is fuel vapor passing thru the top of the tank but after 15 years ??? Anyway I stuck a pin in each one to let the air out and the bubbles dropped flush with the rest of the skin. I quess at this point I will put a damp rag over each "bubble" that I pricked and apply a hot iron in order to shrink the fabric a little and possibly reactivate the glue. Any body ever have this happen? It is only on the right tank and is spread pretty much across the tank area. I was pretty much mentally preparing to yank these tanks out sometime after the first of the year and install new tanks because of the gasohol that is mandated after the first of the year but I hate to do it sooner. In fact I don't want to do it at all. Anyway I will keep a jaundiced eye on it (as I have the Kream in my tank) and prick and iron as necessary (sounds bad huh Lynn )?
        Dick Maddux
        Fox 4
        Milton,Fl
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Lynn Matteson
				 Posted: Sun Sep 06, 2009 5:31 am    Post subject: bubbles under the skin |
				Sounds bad, alright, but how 'bout injecting some of the proper
 "glue" into those pricked holes? In the model planes we would just
 prick the holes and run an iron over the area, activating the
 adhesive. But in our "real" planes, maybe the person who applied the
 covering over the tank area didn't apply enough Poly Brush over the
 area. At least that's what I recall doing to mine. I know I applied
 Poly Brush over the ribs and the false ribs (yes, I made up false
 ribs to go over the tanks), but have to admit that I don't recall
 whether I applied it over the whole tank or not...I'll have to look
 at my pictures or re-read the directions which I followed to the
 letter (those that made sense, anyway..: )  ).
 Lynn Matteson
 Jabiru 2200, #2062, 758.3 hrs
 Sensenich 62"x46" Wood prop
 Rotec TBI-40 injection
 Status: flying
 On Sep 6, 2009, at 8:50 AM, Catz631(at)aol.com wrote:
  	  | Quote: | 	 		   You know, it's always something! Yesterday I noticed some very
                       Dick Maddux
                       Fox 4
                       Milton,Fl
  www.matronics.com/contribution _-
  _________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
		Lynn Matteson
				 Posted: Sun Sep 06, 2009 1:24 pm    Post subject: bubbles under the skin |
				Now that I look at the tank areas of my wings, I see that the fabric
 IS bonded to the tanks, but only because the Poly Brush soaks through
 the fabric, and where it touches the tanks, it is bonded to the
 tanks. Where it is not in contact with the tank....where it lifts
 away to tangent up and over each rib....it is of course not bonded
 there. So I guess if I was not going to remove the tanks, I would
 either inject some Poly Brush under the bubble, which might soften
 the color coat, and therefore require some finish work, or MEK the
 whole area down to the bare fabric, and then apply Poly Brush
 liberally through the fabric, thereby bonding the fabric to the tank.
 But before doing this, I'd make sure that the fabric was shrunk with
 the iron.
 Then do the normal spray coats of Poly Brush, Poly Spray, etc. At
 least that's the way I THINK it should happen....I've been wrong
 before though....once. : )
 Lynn Matteson
 Jabiru 2200, #2062, 760.3 hrs
 Status: flying
 On Sep 6, 2009, at 9:27 AM, Lynn Matteson wrote:
  the covering over the tank area didn't apply enough Poly Brush over
  the area. At least that's what I recall doing to mine. I know I
  applied Poly Brush over the ribs and the false ribs (yes, I made up
  false ribs to go over the tanks), but have to admit that I don't
  recall whether I applied it over the whole tank or not...I'll have
  to look at my pictures or re-read the directions which I followed
  to the letter (those that made sense, anyway..: )  ).
  Lynn Matteson
  Status: flying
 > Lynn )?
 >                       Dick Maddux
 >                       Fox 4
 >                       Milton,Fl
N369LM |
		n61kf
  Joined: 27 Aug 2006 Posts: 23 Location: Waynesville Ohio
				 Posted: Sun Sep 06, 2009 3:33 pm    Post subject: Re: bubbles under the skin |
				Dick,
  I have the same thing going on the surface over my tanks. I have not attempted a cure yet, but was leaning toward injecting some thinned polytac under the bubbles.
 I had this same thing happen with poly-fiber over fiberglass leading edges on my Skybolt, so I'm not so sure that fuel has anything to do with it.
  _________________ Keith Schneider
Red Stewart Airfield
Waynesville Ohio
KF IV 912ul |
		lcfitt(at)sbcglobal.net Guest
				 Posted: Sun Sep 06, 2009 6:44 pm    Post subject: bubbles under the skin |
				Lynn,
 Got a question.  Are the bubbles under the fabric, or between the fabric and
 finish coat?
 I had very small bubbles  - to 1/4", most much smaller between the fabric
 and finish coat, and they were all filled with fuel.  I resloshed the tank,
 and lived with the bubbles.  I was able to reduce the larger ones by shaving
 with a razor blade and touching up the aerothane with a touch up brush.
 If they are larger and under the fabric, maybe one suggestion.  I found once
 that using one of the Polyfiber adhesives - solvent based, caused an ugly
 wrinkling of the paint layer - sort of like crinkle paint.  I then tried
 injecting unthickened structural adhesive and moving it around under the bad
 area with a roller.  That worked fine and no change to the surface.
 Lowell
		Lynn Matteson
				 Posted: Sun Sep 06, 2009 7:07 pm    Post subject: bubbles under the skin |
				Lowell-
 I assume you meant to address this to Dick...he's the one with the
 bubbles. : )
 Lynn Matteson
 Status: flying
 On Sep 6, 2009, at 10:31 PM, Lowell Fitt wrote:
  <lcfitt(at)sbcglobal.net>
  Lynn,
  fabric and finish coat?
  fabric and finish coat, and they were all filled with fuel.  I
  resloshed the tank, and lived with the bubbles.  I was able to
  reduce the larger ones by shaving with a razor blade and touching
  found once that using one of the Polyfiber adhesives - solvent
  based, caused an ugly wrinkling of the paint layer - sort of like
  crinkle paint.  I then tried injecting unthickened structural
  adhesive and moving it around under the bad area with a roller.
  Lowell
N369LM |
		Dick Maddux
				 Posted: Mon Sep 07, 2009 4:39 am    Post subject: bubbles under the skin |
				Thanks for the replies Lynn,Keith and Lowell ! Got another flight in yesterday. After pricking the bubbles,they are staying flat to the surface so, so far so good. It's nice to know that I am not the only one who has had this problem. I may or may not use the adhesive under the skin depending on how it goes. It looks nice now and you can't tell where I put the hole in the bubbles. They have not reinflated.
                                                      Dick Maddux
                                                      Fox 4
                                                      Milton,Fl
