Ron.McGann(at)thalesgroup Guest
Posted: Tue Aug 18, 2009 7:54 pm Post subject: Low MP/Hi RPM |
Read an article on Vansairforce about pulling power and going full fine to slow down. Following is my question to that forum:
“Hi folks,
Following is an extract from the Lycoming IO 540 operators manual:
"These engines are equipped with a dynamic counterweight system and must be operated accordingly; avoid high engine speed, low manifold pressure operation. Use a smooth steady movement of the throttle (avoid rapid opening and closing). If this warning is not heeded, there could be severe damage to the counterweights, roller and bushings."
So, if we use full fine pitch (high RPM) with the throttle all the way off to slow down, aren't we inducing the condition we are warned against?
I am a philistine when it comes to engine technology, and I'm on a serious learning exercise on the proper management of my engine. But I would have one **** of a time slowing down my -10 without the throttle seriously retarded while maintaining cruise rpm.
A lot has been said about climb and cruise RPM/MP settings. But what are acceptable RPM/MP settings for low speed/deceleration ops and how long can these be sustained before the damage preempted in the Operators Manual is realised??”
This list has been a mine of info for me, so would appreciate your feedback on this one.
cheers,
Ron
RV-10
VH-XRM, flying in Oz
DISCLAIMER:--------------------------------------------------------------------------- This e-mail transmission and any documents, files and previous e-mail messages attached to it are private and confidential. They may contain proprietary or copyright material or information that is subject to legal professional privilege. They are for the use of the intended recipient only. Any unauthorised viewing, use, disclosure, copying, alteration, storage or distribution of, or reliance on, this message is strictly prohibited. No part may be reproduced, adapted or transmitted without the written permission of the owner. If you have received this transmission in error, or are not an authorised recipient, please immediately notify the sender by return email, delete this message and all copies from your e-mail system, and destroy any printed copies. Receipt by anyone other than the intended recipient should not be deemed a waiver of any privilege or protection. Thales Australia does not warrant or represent that this e-mail or any documents, files and previous e-mail messages attached are error or virus free. -------------------------------------------------------------------------------------- [quote][b]
