RV8-List McCalley Governor Screws...
Site Admin
PostPosted: Wed Aug 19, 2009 7:49 am    Post subject: RV8-List McCalley Governor Screws... Reply with quote
I pulled one of the screws out to have a closer look, and it appears that on the McCalley governor they've used a dab of Green locktite on the shaft of the screw. There's defiantly no safety wire holes in the screws. Does Green Locktite seem sufficient?
Matt
At 07:35 AM 8/19/2009 Wednesday, Speedy11(at)aol.com wrote:
Yes, they need to be safety wired. Contact the manufacturer and check to see if the screw heads should have been drilled.
Stan
I noticed that your Allen head screws are drilled for safety wire. Mine aren't.
I wonder if I'm still suppose to safety wire them...?
