		mp.gamble(at)tiscali.co.u Guest
				 Posted: Wed Aug 19, 2009 11:54 am    Post subject: Panel Testing |
				Checking my panel on the bench  before  installation.
  Powered up with 12V and before switching off in a panic, I observed a rise on the voltmeter  which I expected but also a rise on the fuel gauge, the oil pressure and at  least one of the temp gauges .
  What should I expect the standard rotax engine  instruments to read if their sensors are not connected? Have I wrecked them  already?
  Reassurance needed.
  Mike Gamble
  XS 440
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		mikenjulie.parkin(at)btin Guest
				 Posted: Wed Aug 19, 2009 12:19 pm    Post subject: Panel Testing |
				Mike,
 I think you will find they are fine.  To test the function, use a potentiometer.
 Some of the them read full scale, others read min scale when disconnected from the sensor.
 From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of mike gamble
  Sent: 19 August 2009 20:54
  To: Europa-List(at)Matronics.Com
  Subject: Panel Testing
 Reassurance needed.
 Mike Gamble
 XS 440
    	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?Europa-List  | 	  0123456789
  Checked by AVG - www.avg.com
  08/19/09 06:03:00
		budyerly(at)msn.com Guest
				 Posted: Wed Aug 19, 2009 3:36 pm    Post subject: Panel Testing |
				<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]-->  You're OK.
  Most instruments (VDO/Mitchell) read zero (or high ohms) open and  pegged (low ohms) or shorted to ground.  Depends on the sender.  Most  engine instruments use a resister that sends 5 volts to the sender wire.   They read the differential voltage through the sender to ground.  Ground  the sender wire and it should read zero.  Fuel senders are an odd sort,  depends on the manufacturer, type (resistive or capacitance).
  Bud Yerly
  [quote]   ---
				 Posted: Fri Aug 21, 2009 12:24 pm    Post subject: Panel Testing |
				Thanks for the input gentlemen. I wired a variable  resistance box to the sensor terminals as suggested and found that the oil  pressure indication rose as the resistance was increased. Same happened with the  fuel gauge ( Europa supplied mod) so I am reassured!
  Mike Gamble
  440 Mono
