		roberthatton1(at)googlema Guest
				 Posted: Wed Aug 19, 2009 5:09 pm    Post subject: 16.5mm Reamer for Mod 72 |
				Hello All,
 Would anyone in the USA have a 16.5mm reamer I could borrow in order to carry out Mod 72? I am happy to pay for postage and packing.
 Robert Hatton
 email: roberthatton1(at)googlemail.com
 US Cell: +01 303 906 9395
		loboloda(at)execulink.com Guest
				 Posted: Thu Aug 20, 2009 5:43 am    Post subject: 16.5mm Reamer for Mod 72 |
				Robert,
 If you do not find one locally, I have one in Ontario, Canada.
 Dave.
 On 19-Aug-09, at 8:56 PM, Robert Hatton wrote:
 Hello All,
 Robert Hatton
 email: roberthatton1(at)googlemail.com (roberthatton1(at)googlemail.com)
 href="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List
  | 	  [b]
		paul.the.aviator(at)gmail Guest
				 Posted: Thu Aug 20, 2009 6:01 am    Post subject: 16.5mm Reamer for Mod 72 |
				Dave,
 Will you be able to ship this to the US, or will Customs deem that it
 is a "weapon of mass destruction" ?
 Just kidding.
  	  | Quote: | 	 		   On Thu, Aug 20, 2009 at 8:31 AM, david miller<loboloda(at)execulink.com> wrote:
  Robert,
  Dave.
		bdanbish(at)gmail.com Guest
				 Posted: Thu Aug 20, 2009 10:24 am    Post subject: 16.5mm Reamer for Mod 72 |
				Robert,
 There was one floating around that Gary Roberts donated so I'm sure whoever has it will respond soon.
 Dan
 Visit -  www.EuropaOwners.org
		gregoryf.flyboy(at)comcas Guest
				 Posted: Thu Aug 20, 2009 8:51 pm    Post subject: 16.5mm Reamer for Mod 72 |
				Hi Robert,
 Sorry, I just got back from a trip to Florida, so I have only just seen your email.
 I have the 16.5mm reamer that is Garys. It is here in the states, so a  ‘reamer from hell’ shipped through customs and their quadruple glances won’t be necessary!
 Send me your address offsite, and I will be happy to send it on its way.
 Greg
 ________
 Hello All,
 Robert Hatton
    [quote] [b]
		mau11(at)free.fr Guest
				 Posted: Thu Aug 20, 2009 10:21 pm    Post subject: 16.5mm Reamer for Mod 72 |
				Hi all,
 the perfect solution for the mod 72 is to use a dremel 16mm cylinder abrade.
 It is possible to use gently and do not make a damage in the tube.
 Quoting danbish <bdanbish(at)gmail.com>:
  Robert,
  Dan
		christoph.both(at)acadiau Guest
				 Posted: Fri Aug 21, 2009 3:42 am    Post subject: 16.5mm Reamer for Mod 72 |
				I would rather go for a high quality precise 16.5mm tool. It leaves a
 straight clean and well dimensioned bore into which the supplied tubes
 can be inserted with measured slight interference, giving maximum
 contact surface between both inserted tube and bore surface. The Dremel
 is too short and will never be able to achieve this. Dremel bits are no
 way close to top notch industrial quality reamers. I have done the MOD
 and as it goes for the process it was a joy to work with appropriate
 tools.
 I borrowed a reamer from a  dear friend of mine and it was worth every
 bit of postage paid.
 Let's do it right from the start. One less thing to worry.
 Christoph Both
 #223 Classic
 Wolfville, NS Canada
