Posted: Wed Aug 19, 2009 8:20 pm Post subject: Gearbox removal tool |
Hi RobPleasure talking with you.Here is one place that sells a gearbox puller:http://74.125.93.132/search?q=cache:c-3tCsBuyPQJ:www.800-airwolf.com/cpsnews.htm+rotax+912+gearbox+removal+tool&cd=5&hl=en&ct=clnk&gl=usI need one too, if during your search you find a good deal on 2.Ron P.> I am checking over the landing gear after a heavy landing and one of the > supports in the Landing Gear Frame appears to have a slight and small > crack. > Although it still attached to the frame. It does not seem to have been > welded (but I could be wrong), it seems to have been glued in, and I > wonder > if anyone has any advice for how I might remove the support in order to > clean up and subsequently re-attach it? I am taking the opportunity to > clean > up the rest of the Landing gear frame too, which does not display any > other > issues. > > > > I have attached the diagram and a photo to show what I am looking at, > although it is difficult to see the crack. Any advice would be gratefully > received. > > > > All the Best > > > > Rob > > > > Robert Hatton > > email: roberthatton1(at)googlemail.com > > US Cell: +01 303 906 9395 > > > > [quote][b]
topglock(at)cox.net Guest
Posted: Thu Aug 20, 2009 6:43 am Post subject: Gearbox removal tool |
WOW! That's a lot of cash for a simple slide hammer. My guess is that
you could borrow one from your local body/fender guy or just buy a cheap
slide at your local auto paint supplier.
Jeff - Baby Blue
rparigor(at)suffolk.lib.ny.us wrote:
| Quote: | Hi Rob
<http://74.125.93.132/search?q=cache:c-3tCsBuyPQJ:www.800-airwolf.com/cpsnews.htm+rotax+912+gearbox+removal+tool&cd=5&hl=en&ct=clnk&gl=us>
Ron P.
> crack.
> wonder
> clean
> other
> issues.
gratefully
> received.
> All the Best
> Rob
> Robert Hatton
Checked by AVG - www.avg.com
pjeffers(at)talktalk.net Guest
Posted: Thu Aug 20, 2009 8:45 am Post subject: Gearbox removal tool |
I made one, only cost a couple of £'s plus an hour or so. Works just fine.
Pete Jeffers
rehn(at)rockisland.com Guest
Posted: Thu Aug 20, 2009 8:46 am Post subject: Gearbox removal tool |
I removed my gear box with a puller I fabricated with items I found around
my shop. Real simple, I will go find it and post a pic later.
Jerry
Jeff - Baby Blue
Posted: Thu Aug 20, 2009 8:48 am Post subject: Gearbox removal tool |
Hi Jeff"> WOW! That's a lot of cash for a simple slide hammer. My guess is that > you could borrow one from your local body/fender guy or just buy a cheap > slide at your local auto paint supplier."I agree the link I sent is asking alot (nice picture though), should be something that one should have on hand to remove gearbox.It's not just the slide hammer you need, also need the proper fixture to connect to the gearbox.Perhaps someone has some ideas and we could go in on a joint purchase?Ron Parigoris>> Here is one place that sells a gearbox puller: >> http://74.125.93.132/search?q=cache:c-3tCsBuyPQJ:www.800-airwolf.com/cpsnews.htm+rotax+912+gearbox+removal+tool&cd=5&hl=en&ct=clnk&gl=us >> <http://74.125.93.132/search?q=cache:c-3tCsBuyPQJ:www.800-airwolf.com/cpsnews.htm+rotax+912+gearbox+removal+tool&cd=5&hl=en&ct=clnk&gl=us> >> >> I need one too, if during your search you find a good deal on 2. >> Ron P [quote][b]
paul.the.aviator(at)gmail Guest
Folks,
I remove my gearbox every 300 and send it to the local rotax service
center to have the clutch checked out.
I have always been able to remove it by tapping with a plastic mallet.
For me is has always come off quite easily with gentle tapping.
Paul
rlborger(at)mac.com Guest
Posted: Thu Aug 20, 2009 9:16 am Post subject: Gearbox removal tool |
Ron P.
| Quote: | I am checking over the landing gear after a heavy landing and one of the
crack.
wonder
clean
other
issues.
received.
All the Best
Rob
Robert Hatton
peter.rees01(at)tiscali.c Guest
