pr(at)dcanderson.myzen.co Guest
Posted: Mon Aug 24, 2009 1:20 am Post subject: Maplin Snake Scope |
The snake scope advertised by Maplin was mentioned on this forum recently. I bought one but when I came to load the software I was greeted by a warning that the software had not been passed as being compatible with Windows XP and that it was strongly recommended that I terminated the installation. I spoke to Maplin and they said that I should go ahead (as they would do) but I was not prepared to take the risk, and so I have returned the scope. It is a pity because it would be a great improvement on the mirror and torch technique normally employed for inspection of inaccessible parts of aircraft.
If enough people buy them and then return them perhaps Maplin will get around to having the software approved.
Roger Anderson G-BXTD
mikenjulie.parkin(at)btin Guest
Posted: Mon Aug 24, 2009 7:11 am Post subject: Maplin Snake Scope |
Roger,
You will find that there are many programmes/software packages available that give the same message. I think that all the message means is that the software has not been given the official windows seal of approval...
I bought the camera you are talking about and installed the software, it works perfectly with no untoward effects on either of my computers.
You are correct though, it is a great improvement on the torch and mirror.
regards,
Mike (G-JULZ.. ready to go, awaiting paperwork.)
--- On Mon, 24/8/09, Roger Anderson <pr(at)dcanderson.myzen.co.uk> wrote:
From: Roger Anderson <pr(at)dcanderson.myzen.co.uk>
Subject: Maplin Snake Scope
To: "Europa Forum" <europa-list(at)matronics.com>
Date: Monday, 24 August, 2009, 10:18 AM
| [quote][b]
Posted: Mon Aug 24, 2009 7:26 am Post subject: Maplin Snake Scope |
On Aug 24, 2009, at 6:43 AM, Mike Parkin wrote:
| Quote: | You are correct though, it is a great improvement on the torch and
mirror.
Undoubtably...I do try to keep open flames around Ms. Europa to a
minimum...
Sorry my British friends...just couldn't help myself. ))
Fred
asarangan(at)gmail.com Guest
Posted: Mon Aug 24, 2009 2:22 pm Post subject: Maplin Snake Scope |
It is a standard warning for any software that is not formally approved by Microsoft.
I am not sure what's special about this bore scope. If you google "fiber optic inspection scopes" you will find plenty, and most of the ones I've used don't need a computer. It is a snake with a lens on one end.
On Mon, Aug 24, 2009 at 5:18 AM, Roger Anderson <pr(at)dcanderson.myzen.co.uk (pr(at)dcanderson.myzen.co.uk)> wrote:
[quote] The snake scope advertised by Maplin was mentioned on this forum recently. I bought one but when I came to load the software I was greeted by a warning that the software had not been passed as being compatible with Windows XP and that it was strongly recommended that I terminated the installation. I spoke to Maplin and they said that I should go ahead (as they would do) but I was not prepared to take the risk, and so I have returned the scope. It is a pity because it would be a great improvement on the mirror and torch technique normally employed for inspection of inaccessible parts of aircraft.
arget="_blank">http://www.matronics.com/Navigator?Europa-List
tp://forums.matronics.com
