				 Posted: Sun Aug 23, 2009 7:52 am    Post subject: Fuel pumps |
				Hi Guys...
 After biting the bullet and ordering a RAM Performance Sube EA81
 derivative engine, I must now deal w/ aux. fuel pump selection...I've
 been planning on installing two for redundancy downstream from a
 single gascolator. Acft Spruce lists a number of different models of
 Facet fuel pumps.
 	http://www.aircraftspruce.com/catalog/eppages/facetpumps.php
 There's a notation at the bottom of the page stating that "the above"
 fuel pumps "do not feature an anti-siphoning valve and fuel will flow
 through them in event of pump failure". That would seem to indicate
 that if using two of them, they should be installed in series rather
 than parallel in order to avoid loss of fuel pressure by having the
 operative pump pumping fuel back thru the failed pump instead of to
 the engine. (I'm presuming that an anti-siphoning valve functions as a
 back flow preventer.)
 I'd welcome comment on my reasoning and any suggestions on alternate
 brands of pumps.
 Fred
		frans(at)paardnatuurlijk. Guest
				 Posted: Sun Aug 23, 2009 8:24 am    Post subject: Fuel pumps |
				Fred Klein wrote:
  	  | Quote: | 	 		   There's a notation at the bottom of the page stating that "the above"
  through them in event of pump failure". That would seem to indicate that
  if using two of them, they should be installed in series rather than
  parallel in order to avoid loss of fuel pressure by having the operative
  pump pumping fuel back thru the failed pump instead of to the engine.
 I would install them in the same way as recommended with the Europa
 engine. That is, in series with two external one-way valves. The one-way
 valves act as a bypass for the non-functioning fuel pump.
 Why, you might ask, the fuel pumps flow through anyway? Well, if a fuel
 pump is broken, you can't count on anything. Maybe just the motor gave
 up the ghost, but it is also possible that a vane broke off and is now
 blocking the stream, or the axle broke and the entire pump section
 scattered in pieces, or something downstream of the filter got loose and
 plugged the pump, or whatever. The fuel pump might let the fuel through,
 but it might also not. If all this could never happen, you didn't need a
 secondary fuel pump anyway. Just make sure that if you take one fuel
 pump completely out of the equation, you can still get fuel to the engine.
 Frans
				 Posted: Sun Aug 23, 2009 10:17 am    Post subject: Fuel pumps |
				 	  | Quote: | 	 		   I would install them in the same way as recommended with the Europa
  way
 Thanks Frans...sage advice as I've come to expect from you. I'll be
 doing further research w/ regard to desired pressures, etc.
 BTW, how are you coming?...still looking for first flight this fall?
 Fred
				 Posted: Sun Aug 23, 2009 12:41 pm    Post subject: Fuel pumps |
				Fred Klein wrote:
  	  | Quote: | 	 		   Thanks Frans...sage advice as I've come to expect from you. I'll be
 Yep. Well, no, make it winter.   Next month the airplane will go to a
 professional painter. Interior is already finished. I just have to go
 through a long list with various small issues, but we are slowly getting
 there.
 Your wing root fairings are installed. Took me some headaches to do it
 in such a way that the airplane can still be easily transported, that a
 conversion to glider wings remains possible, and that the result is not
 only airworthy but also pretty and functional. I think I succeeded in
 that.   Will try to find some time to post some pictures.
 Frans
