Problem with wiring for the elevator trim.
mosquito56
PostPosted: Wed Aug 26, 2009 4:26 pm    Post subject: Problem with wiring for the elevator trim. Reply with quote
I purchased a kit that the owner had done the 2 day build seminar with. Consequently, the rudder and elevator were complete when I purchased the kit.
The elevator trim motor has no holes to run the wires into the fuse. I really don't want to re-open the elevator and was wondering if I could rivet some wire fasteners near the elevator hinge doubler. Another thought was to glue the wire to the doubler with heat-wax gun.
Any ideas would be appreciated.
Don
Don Merritt- Laredo, Tx
Thruster87
PostPosted: Wed Aug 26, 2009 9:06 pm    Post subject: Re: Problem with wiring for the elevator trim. Reply with quote
Don
Just did mine by putting in 3 x rivnuts into the elevator spar below the hinge and then using Adel clamps.It then fits nicely under the stab with another clamp on the down stop. Hope that helps
mosquito56
PostPosted: Wed Aug 26, 2009 9:45 pm    Post subject: Re: Problem with wiring for the elevator trim. Reply with quote
Adel clamps, Aircraft spruce?
naumuk(at)windstream.net
PostPosted: Thu Aug 27, 2009 6:41 am    Post subject: Problem with wiring for the elevator trim. Reply with quote
Don-
Yes. They come in different sizes. I just happen to have a bag of 1/4"
in front of me and they're part number MS21919-WDG4.
Bill
Gig Giacona
PostPosted: Thu Aug 27, 2009 7:07 am    Post subject: Re: Problem with wiring for the elevator trim. Reply with quote
And don't worry about getting to many. You will use them a lot when doing the wiring and maybe in a few places without wiring.
W.R. "Gig" Giacona
601XL Under Construction
mosquito56
PostPosted: Thu Aug 27, 2009 6:49 pm    Post subject: Re: Problem with wiring for the elevator trim. Reply with quote
order 20, thanx a bunch
