Curt.Thompson(at)verizon. Guest
Posted: Thu Aug 27, 2009 6:38 am Post subject: Fitting wings to fuse |
I'm ready to fit up the wings to the fuselage. Is there a sheet in the
drawings or a page in the "Photo Assembly Guides" that describes how to
this? It looks like 7V10 shows a 75mm dihedral. How do I set the incidence
angle? Is the top of the horizontal stab, bottom of the wing, and the
reference E-A line (7F15) all parallel? I assume that the forward edge of
the right/left wing are aligned (no swept angle).
Curt Thompson
Plans building CH701
Redmond, WA, USA
Harvey Richards
Posted: Thu Aug 27, 2009 8:10 am Post subject: Re: Fitting wings to fuse |
Mark Townsend did a blog on the Zenith Aero website about fitting the wings. I think it entailed drilling the forward holes for the wing spar then leaving the drill bit in place. The rear posistion was set with a string above the main spars by lining them up.
_________________ CH 701 |
dougsnash
Posted: Thu Aug 27, 2009 8:12 am Post subject: Fitting wings to fuse |
Hey Curt, I have to agree that the plans are a little vague in this area. I just mounted my wings in the last month and had to do some real head scratching to come up with a plan. The fisrt step is to set up your rear spar mount. The fit of the inboard end of the training edge against the fuselage kind of sets where the wing will live.
Once you have the rear of the wing located, run a string down the spar line to eliminate the forward or rearward sweep in the wings and set the dihedral. I am at work right now so I don't know which page it is on in the plans but there is a diagram showing this and some other information there (not a lot).
The incidence angle seems to be set by the location of the front and rear spar mounts and there is not a lot of adjustment there. To set the dihedral, level the fuselage and measure up the the spar string at rib #1. This distance should be 75mm (if I remember correctly).
The biggest advice I can give is don't drill any of the spar holes until you are sure that everything is as close to perfect as you can get it. Start out with a pilot hole of 3/32" and drill out to 5/16 in stages. It is possible to make minor adjustments as you drill the holes out to final size but not a lot.
Hope this helps a bit
Doug MacDonald
CH-701 scratch Builder
NW Ontario, Canada
--- On Thu, 8/27/09, Curt Thompson <Curt.Thompson(at)verizon.net> wrote:
| Quote: | From: Curt Thompson <Curt.Thompson(at)verizon.net>
Subject: Fitting wings to fuse
Received: Thursday, August 27, 2009, 9:28 AM
--> Zenith701801-List message
posted by: "Curt Thompson" <Curt.Thompson(at)verizon.net>
describes how to
the wing, and the
the forward edge of
Curt Thompson
Redmond, WA, USA
__________________________________________________________________
Make your browsing faster, safer, and easier with the new Internet Explorer® 8. Optimized for Yahoo! Get it Now for Free! at http://downloads.yahoo.com/ca/internetexplorer/
Harvey Richards
Posted: Thu Aug 27, 2009 8:17 am Post subject: Re: Fitting wings to fuse |
The Blog was under Can-zac and titled Wing Attatch
ronlee
Posted: Thu Aug 27, 2009 9:01 am Post subject: Re: Fitting wings to fuse |
Make sure that each wing has the same angle of attack as the other. If they are even a little it will act as a propeller and you will end up with a heavy wing. I use a four foot level with a stand off. I leveled from the main spar to the rear spar and adjusted from wing to wing until they were identical. When all was right I clamped and drilled.
_________________ Ron Lee
Tucson, Arizona |
Posted: Thu Aug 27, 2009 9:34 am Post subject: Fitting wings to fuse |
That was useful but didn't answer my question about incidence angle. It
seems to me that the angle of the horizontal stab to the wing would be
important.
Curt
Harvey Richards
Posted: Thu Aug 27, 2009 11:55 am Post subject: Re: Fitting wings to fuse |
The direction to the Blog was to answer the question of wing sweep.
tbonsell(at)luxuria.com Guest
Posted: Fri Aug 28, 2009 6:20 am Post subject: Fitting wings to fuse |
Yeah I just put my wings on.
In the end I had a water level on the fuse, a water level from wingtip
to wing tip, two tape measures from wingtips to tail, a string from
wingtip to wingtip for the 75mm, horizontal laser level for fuse and
tail and a digital level for incidence. No bubble levels.
It took a long long time.
Posted: Fri Aug 28, 2009 7:47 am Post subject: Fitting wings to fuse |
I found some info in the list archive that indicates that the incidence
angle should be zero. One builder indicated that he have to lower the front
of the horizontal stab by 1/2 inch.
It took most of the day but I got the wings and horizontal stab mounted. My
water level came in real handy.
Curt
joemotis(at)gmail.com Guest
Posted: Fri Aug 28, 2009 6:16 pm Post subject: Fitting wings to fuse |
| Quote: | | I am having a bit of trouble making the nose ribs on the form block. Using the vise grip fluting tool from Spruce but maybe the 3/8 rod tool shown in the prints would work better. Any helpful hints? |
Joe Motis
750 plans and Pietenpol assistant
http://www.matronics.com/Navigator?Zenith====================
http://forums.mle, List Admin.
