Cowl Fitting ( the stuff nightmares are made of)
lwhitlow
PostPosted: Sun Aug 30, 2009 3:18 pm    Post subject: Cowl Fitting ( the stuff nightmares are made of) Reply with quote
Hi All
I'm trying to fit the cowl (601XL Jab 3300 with the Jab Cowl)
Look at the attached pictures When I get the thing lined up so the air intakes line up and are symmetrical the centering of the prop shaft is off.. WAY OFF Ok so which is it Center the prop and not center the air intakes?? (seem bad for cooling to me) or center the air intakes (and it looks like *&*^%^&*)
OK someone whos been here before guide me
Larry Whitlow
601XL
 Filesize:  353.67 KB
 Viewed:  2195 Time(s)
 Filesize:  345.86 KB
