jgswartout(at)gmail.com Guest
				 Posted: Wed Sep 02, 2009 2:47 pm    Post subject: 801 big tires |
				Bill, how did you attach your front float struts to the fuselage?  I have drawings from CAW showing basically a quarter-inch-thick tang sandwiched between the firewall and lower motor mount, sharing the motor mount bolt.  This tang is bent and bolted to the strut.  It seems "all wrong" to me--multiplying the shear stress on the motor mount bolt not to mention adding much to the tension stress.  If you did it that way, how's it working out?
  On Tue, Jul 14, 2009 at 12:32 PM, Keystone Engineering LLC <keystone(at)gci.net (keystone(at)gci.net)> wrote:
  [quote]--> Zenith701801-List message posted by: Keystone Engineering LLC <keystone(at)gci.net (keystone(at)gci.net)>
 I have 8.50x6 on the mains.  I looked into having an 8.50 nose fork bent but
 it was a couple of grand more than I though I wanted to spend.  If you
 really go into places that need that big of tires I suspect you will tear up
  the plane.
 This spring I was in and out of a 350' strip where the plane was sinking in
 about 1".  I would not go in with two but with one it worked.
 I too would like to see pics!
 Bill Wilcox
  Valdez, Alaska
 N801BW
 460 hrs
 On floats!
 Does anyone know what type of modifications need to be done to a CH-801 to
 accomidate 26 - 30 inch Tundra tires and what tire size/mods need to be don
  e to the front gear nose fork if a larger tire was placed there as well?-
  I'm just curious to find out what-expenses might be incurred outsi=========
  , 7-Day Browse, Chat, FAQ,
  ="http://www.matronics.com/Navigator?Zenith701801-List" target="_blank"=========
   http://forums.mle, List Admin.
  |  | - The Matronics Zenith701801-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
