				 Posted: Sat Sep 05, 2009 6:13 pm    Post subject: Tail Wire Tangs Breaking And other Tail   Brace Issue Contin |
				Kolbers,
 Got to wondering what the loads would be on the upper tail cables and tangs.
  I scaled out the FireFly drawings for the horizontal stabilizer and
 elevator.  By drawing this up and cutting out the combined profile for one
 side, I could find the centroid of the area.  This is the spot that one
 could place all the load that is equivalent to the load being spread over
 the whole surface.  I know this is not real but for purposes of finding the
 table tension under load it works.
 The triangle made up of the cable and tangs, the vertical tail post and
 stabilizer attachment points make up a right triangle of 25.5 inches high,
 34 inches wide with a 42.5 inch long side.  The load point turned out to be
 15 inches from the inside hinge point.
 If one assumes that the FireFly horizontal tail surfaces must hold up 100
 pounds in one G flight, then the load on one side would be 50 pounds.  By
 summing moments and forces and applying a little trig, one can calculate the
 cable tension.  In this case it turns out to be 37 pounds.  If one pushes
 the load on up to six G's, the cable tension will increase to 222 pounds.
 This is far short of the 2,000 pound load carrying capability of 1/8 inch
 cable.
 The compression load on the horizontal stabilizer rear member will go from
 29.4 to 176.4 pounds.  The rudder post has to work a little harder because
 it must sustain the load of both sides, so it will go from 61.2 to 367
 pounds at six G's.
 It looks like Dennis did a good job, in that, there is plenty of reserve in
 the design.  The cables and the tangs should be adequate as long as one does
 not over tighten the cables.
 Pre-flight inspections are good.
 Jack B. Hart FF004
 Winchester, IN
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		jlsk1(at)frontiernet.net Guest
				 Posted: Sat Sep 05, 2009 6:23 pm    Post subject: Tail Wire Tangs Breaking And other Tail   Brace Issue Contin |
				NICE JOB !
 Jim Kmet
		henry.voris
  Joined: 02 Mar 2007 Posts: 116 Location: Pueo Field, Kula, Maui
				 Posted: Sat Sep 05, 2009 9:49 pm    Post subject: Re: Tail Wire Tangs Breaking And other Tail   Brace Issue Co |
				Clear thinking...
 Thanks Jack.
  _________________ Henry
Firefly Five-Charlie-Bravo
Do Not Archive |
