Oil
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List
n395v
PostPosted: Mon Sep 07, 2009 5:32 am    Post subject: Oil Reply with quote
Aside from cold weather ops and having to warm up a little longer is there any problem with using aeroshell 120W in the M14?
- The Matronics M14PEngines-List Email Forum -
http://www.matronics.com/Navigator?M14PEngines-List
Milt
william(at)netpros.net
PostPosted: Mon Sep 07, 2009 8:13 am    Post subject: Oil Reply with quote
I live in central CA, where its gets +100F i the Summer and down to
only ~30F in Winter. The A/P at my local FBO has a lot of time with
American round engines, and has found the mutli-weights (I think it'2
25-60) have worked best for him. That's what I use, happily now for
over 200 hrs.
Of course the big round engines guys have a different story on this topic:
http://www.ww2aircraft.net/forum/engines/radial-oil-shell-phillips-15120.html
And why 'Precision Engine' says single weight is better:
http://www.precisionengines.com/pdf/oilBulletin.pdf
And this from Aircraft Spruce on the benefits of multi-grade oil:
"X/C 25W-60 is the first and only multiviscosity aviation oil
designed and approved for radial engines originally designed to run
on 120 grade. Pilots and mechanics will notice immediate benefits
with X/C 25W-60 over single grade oils. Benefits such as improved oil
flow at startup, quicker warm-up time, cooler operating temperatures
and a cleaner operating engine. X/C 25W-60 also has proven corrosion
protection in extreme conditions. X/C 25W-60 can be used year-round,
during break-in and on to TBO."
http://www.aircraftspruce.com/catalog/eppages/phillips66XC.php
I also throw this in from MICROLON since I have treated all my car
and a/c engines with it. It really does work:
http://www.microlon.com/aircraft_engine_treatment.php?PHPSESSID=81569930d138350b927be406fcb8410a
At 06:32 AM 9/7/2009, N395V wrote:
Aside from cold weather ops and having to warm up a littlt longer is
Milt
2003 F1 Rocket
2006 Radial Rocket
http://forums.matronics.com/viewtopic.php?p 61854#261854
__________ Information from ESET Smart Security, version of virus
signature database 4403 (20090907) __________
The message was checked by ESET Smart Security.
over 200 hrs.
Milt
2003 F1 Rocket
2006 Radial Rocket
george(at)gesoco.com
PostPosted: Mon Sep 07, 2009 10:12 am    Post subject: Oil Reply with quote
Ok for warm or hot weather, Takes too long to warm up in cool or cold
weather.
George Coy
CAS Ltd.
714 Airport Rd.
Swanton VT 05488
802-868-5633 off
802-363-5782 cell
george.coy(at)gmail.com
http://coyafct.com/
SKYPE george.coy
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List All times are GMT - 8 Hours
