ElleryWeld(at)aol.com Guest
Posted: Sat Apr 08, 2006 6:06 am Post subject: reusing the H section in a rebuild |
it is posible to reuse the H section as I did when replacing boom tube I cut
both sides of the old tube for a template be carefull not to get them mixed
up Right and left ,get your 3/8 holes in the tube so they match the cage
slide your H section inside and run the bolt through the templates and new tube
start drilling from the 3/8 hole outward in both directions installing clecos
as you go I did it this way and hit every hole without a problem I hope this
helps you out
Ellery in Rebuilt Firestar
herbgh
Posted: Sat Apr 08, 2006 8:32 am Post subject: reusing the H section in a rebuild |
Guys
Tracing paper and the large bolt hole as a guide works also.. Done
it two or three times.. Herb
On Sat, 8 Apr 2006 10:04:25 EDT ElleryWeld(at)aol.com writes:
tube I cut
them mixed
cage
and new tube
installing clecos
hope this
helps you out
ElleryWeld(at)AOL.COM Guest
Posted: Sat Apr 08, 2006 11:33 am Post subject: reusing the H section in a rebuild |
you can use paper if you want but the old tube will help you from a slip with
that drill in an expensive piece of tube, its your choice how much tube do
you want to buy
the old tube is easy to cut use a skill saw just cut it a couple inches
wide and long enough so you can secure the ends with a couple of stainless steel
hose clamps and you will have alot better jig that will prevent a slip of your
drill
Ellery
WhiskeyVictor36(at)aol.co Guest
Posted: Sat Apr 08, 2006 6:22 pm Post subject: reusing the H section in a rebuild |
In a message dated 4/8/2006 3:34:26 P.M. Eastern Standard Time,
with
Ellery,
Expensive is right, especially when you add shipping costs.
Bill Varnes
Original Kolb FireStar
Audubon NJ
In a message dated 4/8/2006 12:33:19 P.M. Eastern Standard Time,
herbgh(at)juno.com writes:
Herb,
Thanks for the confirmation of procedure. But why have you already done it
2 or 3 times?
Bill Varnes
Audubon NJ
In a message dated 4/8/2006 10:07:12 A.M. Eastern Standard Time,
cut
tube
clecos
Ellery,
Thanks for another solution to match drill the holes.
Bill Varnes
Audubon NJ
herbgh
Posted: Sat Apr 08, 2006 11:28 pm Post subject: reusing the H section in a rebuild |
I rebuilt a Mk III and an Ultrastar... Bought both of them as wrecks
. Herb
Herb,
done it
2 or 3 times?
Bill Varnes
Audubon NJ
