pj.ladd(at)btinternet.com Guest
Posted: Mon Sep 07, 2009 8:55 am Post subject: Microbes in the fuel |
There has been much said about filters lately.
This may be a new slant. I have paraphrased it from an article in the current `Microlight magazine.
After many months investigating sudden loss of pwer in their 503 during which everything, fuel lines, pump,ignition etc., was changed,cleaned, and so on it was found that the filter was being blocked by microbial contamination which grew into `colonies`..
This was intoduced into the fuel supply through water in the premix oil. Oil is hygroscopic(attracts water) the oil was being drawn from a 20 litre drum as needed. Once opened the oil in the drum attracted water and the bacteria attached themselves to the wall of the fuel tank.The bacteria grew on the fuel filter mesh because that was where daylight shone through the glass.
For those with 4 strokes. Biofuel is now added to petrol and this contains ethanol which is highly hygroscopic so the same thing may be expected to happen.
The problem was cured by introducing a magnetic field into the fuel line. This appaerently disrupts the cellular structure of the microbes and prevents them growing big enough clusters to block the filter.
Try www.purefueltechnologies.com
Hope I don`t get `done` for copyright infringement.
Cheers
Pat
Posted: Mon Sep 07, 2009 5:23 pm Post subject: Microbes in the fuel |
Patrick/Gang:
I'll take a dozen of those items. My fuel is long past due for some serious straightening.
West Yellowstone, MT
[quote] This appaerently disrupts the cellular structure of the microbes and prevents them growing big enough clusters to block the filter.
Pat
_________________ John Hauck
Titus, Alabama |
Posted: Tue Sep 08, 2009 1:40 am Post subject: Microbes in the fuel |
Hi john,
I'll take a dozen of those items. My fuel is long past due for some serious straightening.>>
Hi John,
I must say that I did wonder why this problem had not cropped up and been traced to its source before this.
No reason to doubt the story. though. It was reported as pukka gen, not an advert.
Pat
russ(at)rkiphoto.com Guest
Posted: Tue Sep 08, 2009 4:53 am Post subject: Microbes in the fuel |
PatWe used to add "PRIST" to avgas; a bactericide that reportedly killed the bacteria living on the fuel-water interface.
Can't prove it worked, but no troubles and it made us feel better, esp in remote areas.
On the big marine diesels; 600HP and up -- in the tropics algae can grow into big enough clumps to plug up the humungous fuel filters, 6-7" across. If not run every day or two we added "BIOBOR", a powerful algicide
Russ
PS On this side of the pond, if you're not making a profit (or trying to) on pirated copyrighted works, no one seems to care.
I think you're safe.
On Sep 7, 2009, at 12:54 PM, pj.ladd wrote:
| Quote: | There has been much said about filters lately.
Cheers
Pat
beauford
Posted: Tue Sep 08, 2009 6:31 am Post subject: Microbes in the fuel |
Brothers Pat and John:
Being a slow-learner, am still pondering whether the evidence warrants bolting magnets onto our fuel lines just yet.... or, of more immediate consequence, whether it would be worth lining my Adidas with refrigerator magnets to handle the athlete's foot mess...
There is sure a lot of skepticism in the literature and across the internet about the claims that magnets can kill algae by affecting cellular reproduction... especially when the "target" cells are exposed to the field for only a second or two as they pass through the little magnet unit on the fuel line. Anecdotal evidence can be dangerous.
As one astute observer pointed out, if magnetism really does disrupt organic cellular function and reproduction, consider then what effect prolonged exposure to super high magnetic fields should be capable of doing to cells -- There would have to be sick and dying freshly-imaged patients littering the exits and parking lots of every MRI facility in the world, and the facilities themselves would be bacterially sterile throughout...
...just a thought...
non-ferrous beauford
FF-076
Brandon, FL
Possums
Posted: Tue Sep 08, 2009 10:54 am Post subject: Microbes in the fuel |
At 10:29 AM 9/8/2009, you wrote:
| Quote: | Brothers Pat and John:
Cynical beauford........
I've got a "Magnetic Fuel Saver" on my plane
and I've had to put an overflow valve on both tanks. On long trips
I end up with more gas than I started with.
You see Norm
With a magnetic field we can increase the internal energy of the fuel,
causing specific changes at a molecular level. Increasing the internal
energy to obtain more easier combustion. The molecules fly apart
easier, join with oxygen easier and ignite easier. 'Ionization' implies
that the fuel acquires a 'charge' and molecules of like charge repel
each other, this makes fuel dispersal more efficient. Then if you
charge the air to the opposite polarity, then the fuel and oxygen
combine far quicker than 'normal'.
It's all right there on the Internet!
http://www.tinet.cat/~sje/mag_fuel.htm [quote][b]
_________________ Possum |
Dana
Posted: Tue Sep 08, 2009 2:51 pm Post subject: Microbes in the fuel |
At 12:54 PM 9/7/2009, pj.ladd wrote:
| Quote: | The problem was cured by introducing a magnetic field into the fuel line. This appaerently disrupts the cellular structure of the microbes and prevents them growing big enough clusters to block the filter.
Try www.purefueltechnologies.com |
Sounds like a new slant on the fuel line magnets that were supposed to "break up hydrocarbon clusters" and give you an amazing increase in your gas mileage. When the government came down on them for false advertising, they must've found a new angle to sell those things...
-Dana
The most important and least understood aspect of life in America is stupidity.
-- F.Zappa [quote][b]
Posted: Wed Sep 09, 2009 7:16 am Post subject: Microbes in the fuel |
they must've found a new angle to sell those things...>>
Hi Dana,
Could be, I suppose but axccording to the article the guy in question did a hell of a lot of work trying to solve the problem before he finally got to the magnet thing.
I dont know if the Microlight mag. is available on line but you might try BMAA. Org.
i am surprised that the problem and the answer have not surfaced before, we have all been flying 2 strokes a long time. 4 strokes are different as we have only had the 10% addition to fuel rule since May.
Magnetic bangles didn`t work for my arthritis either.
Cheers
Pat
Posted: Wed Sep 09, 2009 7:19 am Post subject: Microbes in the fuel |
combine far quicker than 'normal'.>>
So thats where all that fuel on the hangar floor has been coming from. It seems that the effect continues even with the engine switched off
Cheers
Pat
Posted: Wed Sep 09, 2009 2:47 pm Post subject: Microbes in the fuel |
Hi Russ,
<<On the big marine diesels; 600HP and up -- in the tropics algae can
powerful algicide>>
One of the things that the guy mentioned in his article which I did not pass on was that he found that the problem was well known in the marine business. I think they gave him the lead on the magnet thing..
Everything conspires to stop me flying. Lovely day to day could have flown except that I was sceduled at middayto take my wife to watch my stepson, who works for the BBC, filming locally. As it takes at least 3 hours to get to the field, fly and put her away that was the morning shot.
This afternoon was shot because I had a church engagement around 7 this evening. Evenings are closing in and it is too dark to fly by about 8.
Off to our cottage at the seaside tomorrow until Sunday The WX? Super for the next 3 days.
Someone up there doesn`t like me.
Cheers
Pat
russkinne(at)mac.com Guest
Posted: Thu Sep 10, 2009 11:06 am Post subject: Microbes in the fuel |
Pat
My sympathies in your having bad wx drag you over the coals. Bummer!
Good thing we can't do anything about the wx, or we'd bust our butts
trying -- but enjoy the coast anyway. Isn't it getting coolish?
Years ago I even tried taping a couple cow-magnets to my fuel line
(car) and it had exactly the effect I thought it would. Zilch!
Have fun,
Russ
Posted: Mon Sep 14, 2009 4:14 am Post subject: Microbes in the fuel |
but enjoy the coast anyway. Isn't it getting coolish?>>
Hi Russ,
Great few days away, hot in the sun and the tide began coming in around 8 in
the morning so a lot of activity in the estuary. Drove into a fly in on
the way home and met a couple of guys from my field. Last time I was at that
fly in I flew the Challenger there.A Lovely sunny day, light breeze but the
temps are dropping. Needed my fleece by evening. North of England dropped 10
degrees yesterday.
Today it is overcast and breezy. Well it would be woudn`t it?
We often get a few weeks of smooth gentle winds around now. Evenings are
shortening. Pretty dusk ( dimpsy as we say in this part of the world) at
around 7.30. Have to get the plane out soon even if it is only to run the
engine.
Cheers
Pat
