Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 28032 Location: Toledo Washington (KTDO) USA
Posted: Wed Sep 16, 2009 9:57 am Post subject: Corrosion Paste On Terminal Lugs... |
What's the common practice regarding that white goo for corrosion protection that B&C sells? I've been gooping up all sides of the posts and connector including the contact faces before I've been bolting these kind of connections together (like the starter lead and battery connections, etc). I was thinking that it was kind of like heatsink compound where you do just that. But is that really the right thing to do with this stuff? Or should it just be added to the outside of the finished connection? If yes, then what should I do with all of these connections I've already made?
Thanks!
RV-8 #82880 N998RV
http://www.mattsrv8.com
Engine Baffling...
_________________ Matt Dralle
mprather(at)spro.net Guest
Posted: Wed Sep 16, 2009 10:43 am Post subject: Corrosion Paste On Terminal Lugs... |
I think the only place it makes much sense is on the terminals for a
flooded cell lead acid battery.. Applying it to the post before
tightening would provide the best protection and not interfere with
conduction through the joint as long as the hardware is torqued
sufficiently.
I'd guess that the starved cell batteries don't really need the stuff.
Matt-
<dralle(at)matronics.com>
Thanks!
RV-8 #82880 N998RV
Engine Baffling...
Posted: Wed Sep 16, 2009 1:49 pm Post subject: Corrosion Paste On Terminal Lugs... |
At 12:54 PM 9/16/2009, you wrote:
If its the same material that was in my catalog
at the time they purchased my inventory, that "goo"
is intended as an anti-corrosion, anti-seize treatment
for threaded fasteners exposed to harsh environment.
| Quote: | I've been gooping up all sides of the posts and connector
At no place I've ever worked for over 40 years did
we "goop" any assembled electrical joint. Every joint
was assembled from shiny, clean, dry components of
proper material and appropriate plating. Where critical
mate-up pressures were to be achieved, the work instructions
called for use of a torque wrench in the final tightening.
In other words, a connection that's properly crafted is
so tightly joined that any goop would be extruded out
of the interface . . . and can only protect the micro-
thin edges of the interface.
I have offered the notion that a di-electric grease
MAY be useful when the OBAM aircraft builder needs to
make up a high-current joint that is subject to harsh
environment and/or located in a very hard-to-inspect
location. 99.9% of all made up electrical joints require
nor would they benefit from any 'treatments'. Getting
the necessary force to achieve gas-tight interconnection
is all that's necessary. Most of those issues are
addressed for you when you use fast-on terminals, crimped
or soldered joints, etc. Things held together with threaded
fasteners have the highest risk of human-factors variables.
Even those are no big deal if you simply take common care
for craftsmanship.
I don't know the qualities of the B&C anti-seize
compound as a prophylactic against environmental degradation
of bolted up electrical joints. It MAY be just fine.
I DO know that plain vanilla silicone grease like
Dow Corning DC4 or
http://www.super-lube.com/silicone-dielectric-grease-ez-52.htm
are specific to the preservation of integrity of electrical
joints. I've got a tube of DC4 that's over 30 years old. I
use it on my tail-light bulb sockets and I've
not had one corrode into the socket in many years. But
I don't find it useful to dope many bolted up electrical
joints.
( -Thomas Paine 1776- )
