		kearney
				 Posted: Fri Jul 17, 2009 6:44 pm    Post subject: GPS Antenna Placement |
				Hi
 As I work my way through canopy hell, I am wondering about the placement of my GPS antenna. Is there any reason it cannot be mounted on the tail cone, just aft of the canopy. I understand it should be mounted as high as possible, but given the canopy is f/g, I was wondering if the tail cone would be acceptable. Comments front the antenna mavens appreciated.
 Inquiring minds need to know.
 Les
 #40643
		rebrunk42(at)gmail.com Guest
				 Posted: Fri Jul 17, 2009 6:58 pm    Post subject: GPS Antenna Placement |
				I put the gps antennas in a recess in the center of the canopy
 Robert E. Brunkenhoefer
 Brunkenhoefer Law Firm, P.C.
 520 Lawrence St.
 Corpus Christi, Texas 78401
 Phone: 361-888-8808
 Facsimile: 361-888-6753
 robert(at)brunklaw.com (robert(at)brunklaw.com)
 On Jul 17, 2009, at 7:41 PM, "Les Kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
 Hi
 Les
 #40643
		Deems Davis
				 Posted: Fri Jul 17, 2009 7:04 pm    Post subject: GPS Antenna Placement |
				Les, I'm not maven, but my gyro stabilized gimble mounted GPS antenna
 pylon seems to be working just fine   .
 Seriously, I have one GPS antenna mounted on the tailcone just aft of
 the fiberglass cabin cover, and the other on the highpoint of the cabin
 cover. I haven't noticed a difference in reception.
 Deems
 Les Kearney wrote:
  Hi
  Les
  #40643
		Kellym
				 Posted: Fri Jul 17, 2009 7:11 pm    Post subject: GPS Antenna Placement |
				Yeah, when are you going to show us your AWACS pylon?
 Deems Davis wrote:
  Deems
  Les Kearney wrote:
 > Hi
 > Les
 > #40643
KCHD |
		kearney
				 Posted: Fri Jul 17, 2009 7:20 pm    Post subject: GPS Antenna Placement |
				Thanks Deems
 Hmmm. I may go with the tail cone as it will be an easier install for me.
 Cheers
 Les
		sfdarton(at)yahoo.com Guest
				 Posted: Sun Jul 19, 2009 11:49 am    Post subject: GPS Antenna Placement |
				The G1000 installation on our company Cessna Corvalis (formerly Columbia 400) has the #1 GPS antenna mounted externally on a short pylon just aft of the cabin. The #2 antenna is mounted aft of that internally. The GPS signal reception is "certified aircraft" exceptional in all phases of flight.
 Steve 40212
 --- On Fri, 7/17/09, Les Kearney <kearney(at)shaw.ca> wrote:
  	  | Quote: | 	 		   From: Les Kearney <kearney(at)shaw.ca>
  Subject: GPS Antenna Placement
  Date: Friday, July 17, 2009, 8:41 PM
  Hi
  As I work my way
  appreciated.
  Inquiring minds
  need to know.
  Les
  #40643
		n277dl
				 Posted: Sat Sep 19, 2009 1:59 pm    Post subject: Re: GPS Antenna Placement |
				Guys...
    I've mounted my GPS antenna on top of the cabin with the small ovhd console from Dave Saylor hiding the wiring.  This is a TNC connector.  The cabin top is about an inch and half thick here.
 Question is what connector.  I've ordered a right angle TNC connector from Stein but it's too short and won't fit through to the antenna.  I've searched around on the web looking for a right angle connector with a longer leg but haven't stumbled across one.
 Then it just hit me that a maybe straight TNC connector would be perfect since I believe I have enough room for the RG400 to bend.
 Or a straight extension would probably work but it'd be another joint in the mix.
 SO... those who've mounted the gps antenna on the top of the console, what have you used for connector and where'd you get it if it is a right angle connector.
 Doug
 Glued the windows in this morning while it was cool.  Windscreen maybe in the morning before church....  getting there.
  _________________ Doug
"Fools" are always more creative than process people and will always find ways to ruin a perfectly good set of processes. |
		Deems Davis
				 Posted: Sat Sep 19, 2009 2:22 pm    Post subject: GPS Antenna Placement |
				I opened up the hole to make room for the right angle and then goudges
 out about 1/4" of the foan and filled it with flox.
 Here's a picture:
 http://deemsrv10.com/album/Final%20Assembly/slides/DSC07129.html
 Deems Davis
 www.deemsrv10.com
 N519PJ
 n277dl wrote:
  Guys...
  Doug
  Doug
  http://forums.matronics.com/viewtopic.php?p 63867#263867
		Tim Olson
				 Posted: Sat Sep 19, 2009 6:40 pm    Post subject: GPS Antenna Placement |
				I just used straight.
 On Sep 19, 2009, at 4:59 PM, "n277dl" <dljinia(at)yahoo.com> wrote:
  Guys...
  joint in the mix.
  Doug
  Doug
