rickofudall
Posted: Mon Sep 21, 2009 7:47 am Post subject: An Older but Good Basic GPS (no aviation data base) |
Did the GPS help or hinder the cat with mousing? My cat keeps losing the mice under the couch while he's tormenting them. It might work better to put the GPS on the mouse, come to think of it.
Rick Girard
On Mon, Sep 21, 2009 at 8:53 AM, pj.ladd <pj.ladd(at)btinternet.com (pj.ladd(at)btinternet.com)> wrote:
[quote] --> Kolb-List message posted by: "pj.ladd" <pj.ladd(at)btinternet.com (pj.ladd(at)btinternet.com)>
Garmin has forced Magellan out of the market now; >>
Hi Russ,
i had a Magellan on my cat. Seemed to be OK but not easy to use. Manual entry of lat and long No GPS was easy to use back then.
Pat
http://forums.matronics.com
le, List Admin.
pj.ladd(at)btinternet.com Guest
Posted: Tue Sep 22, 2009 1:43 am Post subject: An Older but Good Basic GPS (no aviation data base) |
Did the GPS help or hinder the cat with mousing?.
I just knew it!
You will be happy to know that the mousing around the new frapping on the bitter end of the flying jib downhaul (Where the double bowline on a bight is secured just behind the binnacle) has cured the problem. Likewise the baggywrinkle.
Thank you for your interest
Cheers
Pat
rickofudall
Posted: Tue Sep 22, 2009 3:24 am Post subject: An Older but Good Basic GPS (no aviation data base) |
Baggywrinkle - N. ME, usually seen on the large ladies of Walmart or in the mirror, usually under the eyes, after a night of tapping the admiral.
Rick Girard
On Tue, Sep 22, 2009 at 4:43 AM, pj.ladd <pj.ladd(at)btinternet.com (pj.ladd(at)btinternet.com)> wrote:
[quote] Did the GPS help or hinder the cat with mousing?.
I just knew it!
Cheers
Pat
russkinne(at)mac.com Guest
Posted: Tue Sep 22, 2009 5:43 am Post subject: An Older but Good Basic GPS (no aviation data base) |
PatNo tumblehome or deadrise involved? No scuppers??
Russ
On Sep 22, 2009, at 5:43 AM, pj.ladd wrote:
| Quote: | Did the GPS help or hinder the cat with mousing?.
I just knew it!
Cheers
Pat
Posted: Wed Sep 23, 2009 1:58 am Post subject: An Older but Good Basic GPS (no aviation data base) |
Baggywrinkle - N. ME, usually seen on the large ladies of Walmart>>
Nice one, Richard.
Pat
