N4ZQ(at)comcast.net Guest
				 Posted: Thu Sep 24, 2009 5:53 am    Post subject: Ground Loop posibilities |
				In my Lancair, I have two Odessey batteries and the - terminals are
 wired as follows:
 1.	4ga cable from A bat to B bat and from there to starter ground.
 2.	10ga cable from A Bat to B Bat and from there to ground buss
 forward of the panel. This ground buss is
 	electrically isolated from the rest of the airframe as it is mounted
 on glass.
 I can demonstrate continuity between the ground buss and any point on
 the instrument panel and avionics stack as well as any of the control
 cables which penetrate the firewall and attach to the engine. This
 would seem to be made possible by the ground path from the batteries
 directly to the starter ground point. From a ground loop point of
 view, is this anything to be concerned about? Given all the cables
 which attach to the engine and pass through the firewall to the panel,
 I don't see how it would be possible to isolate the starter ground
 cable path to the panel. Maybe this is a non issue and I should just
 get on with building.
 All comments appreciated.
 Angier Ames
 N4ZQ
  |  | - The Matronics AeroElectric-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
