mhubel
Posted: Fri Sep 25, 2009 12:36 pm Post subject: Instrument panel files for CH601XL |
I have posted a set of turbocad files that were used for the CH601XL. These are on http://groups.yahoo.com/group/jabiruengines/files/ you may need to register to access them. The files are under the file name turbocad_CH601_instrument_panel_N708HU.zip
Included in the files are three layers (options->layers) that are the actual holes, the part outlines and the space guidelines. Only the first (black) layer is to be used for fabrication.
The instrument panel was actually made by
Rapid Sheet Metal Inc
Kristen Spratt
603-821-5300
603-889-4266 fax
customerservice(at)rapidsheetmetal.com
This design was $390 (quantity 1) including painting. The cost won't vary much with the layout.
It was 0.090 thick and was painted by Rapid Sheet Metal. It was put on top of the sheet metal already there. All openings in he existing panel were made slightly oversize for ease of alignment.
If you use these drawings and this vendor, I suggest not using any countersunk screw holes as these are 2D drawings and the countersunk holes really don't make it look any better.
_________________ Mark Hubelbank
N708HU
CH601XL
Jabiru 3300
Rotec TBI 40-3 carb
Sensenich ground adj prop.
240 hr TAF
Pictures at photo.hubbles.com |
