P-Mags
bkbrown(at)ashcreekwirele
PostPosted: Sun Apr 09, 2006 7:21 pm    Post subject: P-Mags Reply with quote
Great and not so great...
After much trying I fired up the engine for the first time today. After purging all the lines, I attempted a start. It took many tries to get the engine fired up, but it finally ran. Once it ran, it ran great...until I tried to test the P-Mags by individually cycling their breakers. The engine stumbled hard when I switched the right breaker to the off position, but recovered when I switched it back on. I THINK this indicates that it was not generating it's own power. When I switched off the left P-Mag, the engine monitor showed an 800 RPM increase, but that was bogus because you could not hear any change at all in the engine. As called out in the manual, only one ignition is wired to the ACS2000. All temps were even on CHT/EGT. While the engine was running, I tested both radios, as the engine monitor showed 13.7V. After I shut down, both ICOM A-200's went blank. All other avionics and electronics work fine. No fuses popped, no burned wires.
I guess it's back to the drawing board and YES, I'm more than a little depressed about it. I'll call the Emagair boys this week to see what ideas they have. The P-Mags were installed by the engine builder, and I have not addressed the issue of their timing...but it is disheartening to see that they are apparently not making their own power.
I'll keep the group informed as I stumble through this...
Bob Brown
RV-7A
Wingtips and wing root fairings
fstringham
PostPosted: Mon Apr 10, 2006 5:25 am    Post subject: P-Mags Reply with quote
Bob
Very interesting info as I too am going the p-mag route. I have no idea as
to the problem but look forward to your solution.
As a side note I am about to start the dreaded canopy (tip up). Any advice
out there. At least say a little prayer for .................
Frank (at) SGU and SLC
From: "Karen and Robert Brown" <bkbrown(at)ashcreekwireless.com>
Reply-To: rv-list(at)matronics.com
To: <rv-list(at)matronics.com>
Subject: P-Mags
Date: Sun, 9 Apr 2006 20:16:33 -0700
wires.
Bob Brown
RV-7A
sportav8r(at)aol.com
PostPosted: Mon Apr 10, 2006 5:44 am    Post subject: P-Mags Reply with quote
Pmags will not self-power below about 900 rpm. Also, there is a chance that your Pmag/engine monitor combo will read 2x actual rpm in self-powered mode; mine does this and I hope to make it go away by resetting the mag to another dipswitch seting and reprogramming my GRT engine monitor to expect twice the # of pulses. I bet they have addressed this on their latest model. The tribulations of being an early-adopter Wink
Wait till you experience the in-flight stumble that the heavier-gauge B+ wire is supposed to fix (or new firmware; your choice Wink
-Bill B
RV-6A O-320 dual p-mags/auto plugs
Bob Barrow
PostPosted: Mon Apr 10, 2006 11:30 pm    Post subject: P-Mags Reply with quote
Recommend you go to this group with your question.
http://www.matronics.com/listbrowse/aeroelectric-list/index.html
tried
stumbled
when I
it's own
800 RPM
in the
ACS2000.
both
fuses
depressed
have.
the
apparently
Bob Brown
RV-7A
New year, new job there's more than 100,00 jobs at SEEK
http://a.ninemsn.com.au/b.aspx?URL=http%3A%2F%2Fninemsn%2Eseek%2Ecom%2Eau&_t=752315885&_r=Jan05_tagline&_m=EXT
