jim(at)CombsFive.Com Guest
Posted: Mon Oct 05, 2009 7:23 am Post subject: AP |
Dr Fred Wrote:3. If you have a Trutrak autopilot and the screen is starting to getsome lines and fail and you're thinking about getting it fixed, bettercall and get in line. I went and pulled my unit out as I was thereanyway, called and it will be "several weeks" before they can get to itand get it fixed. Courteous on the phone but obviously overwhelmed bythis problem. Put me on a call back list. Arguh .Another item regarding the AP. If you have the Advanced Flight Systems version of the A/P, you should look at having the the buttons and firmware updated to make it a "real" AFS A/P. There is a firmware change as well as button labeling change that needs to be done. The latest AFS documentation shows the correct buttons. Functionality also changes with the new software.Our display has one pixel row blank as well.Jim Combs (N312F - 120 Hours) [quote][b]
