DAquaNut(at)aol.com Guest
Posted: Sat Oct 03, 2009 9:15 pm Post subject: Props |
Guys,
Now that Power fin has gone out of business what other prop is as light weight, that is also adjustable and rigid? I was intending on getting one for my Firefly, because I was told it did not flex so badly at idle like the Ivo. Also because I need to keep it light.
Ed Diebel
Houston Tx FF# 62
Dana
Posted: Sun Oct 04, 2009 4:13 am Post subject: Props |
At 01:12 AM 10/4/2009, DAquaNut(at)aol.com wrote:
Quote: | Now that Power fin has gone out of business what other prop is as light weight, that is also adjustable and rigid? I was intending on getting one for my Firefly, because I was told it did not flex so badly at idle like the Ivo. Also because I need to keep it light. |
Powerfins are very light, but fragile... bad news for a pusher where the landing gear may kick rocks into it. I watched a MKIII crash after the Powerfin prop exploded on takeoff at about 50' (shouldn't have been a crash but the pilot concentrated on shutting down the engine instead of flying the plane). The owner had repaired nicks in the prop from gravel strikes without realizing the cracks extended all the way through the rigid part into the foam core.
If I was in the market for a plastic prop, it'd be a Warp Drive. Not as light as the Powerfin but very rigid and bulletproof..
Of course if you want light weight there's also the GSC adjustable wood props <http://www.ultralightprops.com/tech_series_props/gsc_tech_groundadjust.htm>. I have one on one of my PPG's; they're beautifully made and less expensive than any plastic prop.
-Dana
(A)bort, (R)etry, (P)retend it didn't happen? [quote][b]
Posted: Sun Oct 04, 2009 6:13 am Post subject: Re: Props |
Remind me when I get home. I disected a Warp Drive prop blade grip and also a GSC. You may change your mind about GSC after you see these two photos.
The reason I started flying Warp Drive Props in 1993, was GSC. I had a GSC 3 blade wood prop mounted on a 582 on my mkIII. During climb out at WOT a blade failed, hit the tail boom, and collected the other two blades. I couldn't afford for this to happen again. GSC promptly sent me a new prop and hub. I promptly sold it.
Moab, Utah
_________________ John Hauck
Titus, Alabama |
flykolb(at)pa.net Guest
Posted: Sun Oct 04, 2009 10:10 am Post subject: Props |
John,
If I knew where your GSC prop blade failed ... I have since forgotten.
Where did the blade fail? I do recall when building a SS for the twin
engine 2si engine package, that I cut out a piece of 6" tubing and made a
doubler plate for the fuselage tube under the prop area. Maybe this was an
inspiration from your GSC prop experience.
Dennis
Posted: Sun Oct 04, 2009 11:41 am Post subject: Props |
Quote: | Where did the blade fail?
Dennis
Dennis S/Gang:
I have an idea the double K&N air filter I was using decided to depart its
normal location and went through the prop. Either that or one blade failed,
hitting the tail boom, and collected the other two blades. Had a large dent
in the tail boom, which was knocked about 5 to 10 degrees out of column.
Had no idea they tail boom was no longer straight until after I landed.
I was in a steep climbing attitude, WOT, when I experienced a very loub
explosion and immediate terrific vibration. I didn't have time to shut down
the engine. When the prop failed, it instantaneously shook both carbs out
of their sockets. Only thing holding them on to the aircraft was the
cables. I had the standard Rotax starter mounted on the mag eng of the 582.
It was hanging by the positive battery cable after the bell housing broke.
I put the mkIII in a shoe box forced landing area. Thank God I had 40
degrees of flaps to get me down and stopped before I hit a large bamboo
thicket. I had to ground loop the mkIII to keep from hitting the thicket.
To add to my delema, the Johnson grass in the field was shoulder high. Did
not put a scratch on the mkIII during the forced landing.
Says a lot for the capability of the Kolb MKIII. Not a classic, because
there were no classics until the MKIIIx came along. Don't change the
designation of my MKIII because of that. I have a MKIII, and TNK designed a
MKIII Extra.
Moab, Utah
Titus, Alabama |
Posted: Sun Oct 04, 2009 1:14 pm Post subject: Props |
Amazing how focussed you attention gets in these circumstances.
-and how glad you feel when you survive intact.
BB
On 4, Oct 2009, at 3:36 PM, John Hauck wrote:
forgotten.
> Dennis
Dennis S/Gang:
depart its normal location and went through the prop. Either that
or one blade failed, hitting the tail boom, and collected the other
two blades. Had a large dent in the tail boom, which was knocked
about 5 to 10 degrees out of column. Had no idea they tail boom was
loub explosion and immediate terrific vibration. I didn't have
time to shut down the engine. When the prop failed, it
instantaneously shook both carbs out of their sockets. Only thing
holding them on to the aircraft was the cables. I had the standard
Rotax starter mounted on the mag eng of the 582. It was hanging by
40 degrees of flaps to get me down and stopped before I hit a large
bamboo thicket. I had to ground loop the mkIII to keep from
hitting the thicket. To add to my delema, the Johnson grass in the
field was shoulder high. Did not put a scratch on the mkIII during
the forced landing.
because there were no classics until the MKIIIx came along. Don't
change the designation of my MKIII because of that. I have a
MKIII, and TNK designed a MKIII Extra.
Moab, Utah
Jim Baker
Posted: Sun Oct 04, 2009 1:22 pm Post subject: Props |
X-SpamReason %%SpamReason%%:
Ed Diebel
This is NOT about how bad Ivo props are,,,many love them.... but
rather one of the reasons I'm not wild about them ( I have a Warp on
mine).
Test flew another gentleman's FS 2 with an Ivo and was really
surprised at the stall characteristics. Just as I approached a stall
the Ivo would "unload"/cavitate and instead of a nice smooth break
the plane would quit flying immediately, not buffet a bit as mine
will. The airspeed would dramatically drop as the prop stopped
producing any thrust whatsoever. Really bad behaviour.....
Jim Baker
580.788.2779
405. 426.5377 cell
Elmore City, OK
Posted: Sun Oct 04, 2009 1:28 pm Post subject: Props |
John, how did you extract the Kolb from the shoebox?
BB
forgotten.
> Dennis
Dennis S/Gang:
the forced landing.
Moab, Utah
Posted: Sun Oct 04, 2009 1:52 pm Post subject: Props |
Quote: | John, how did you extract the Kolb from the shoebox?
BB
Hi Bob B/Gang:
Pulled the wings and trailered it out.
Dinged the leading edge of the upper vertical stabilizer loading into the
trailer. ;-(
Little Mike sent me a "2d" tail boom, and I was back in business in a couple
weeks, only to have the 582 seize. Got it into a small hay field. Wiped
out the landing gear trying to fly it out. That was the last flight of the
mkIII until Bro Jim built new landing gear, and I repaired the damage, and
installed my new 912. That was winter of 93/94. Flew again a couple days
prior to Sun and Fun 1994. Two months later it flew 17,400 miles in 41 days
and 232.0 flight hours. Think I got the bugs worked out of it by then.
mkIII - I break'em. Me and Bro Jim fix'em.
Titus, Alabama |
HShack(at)aol.com Guest
Posted: Mon Oct 05, 2009 3:20 pm Post subject: Props |
In a message dated 10/4/2009 1:15:40 A.M. Eastern Daylight Time, DAquaNut(at)aol.com writes:
Quote: | Now that Power fin has gone out of business what other prop is as light weight, that is also adjustable and rigid? | Check out Hot Prop [formerly Kiev prop]. I prefer it over the Warp.
JetPilot
Posted: Tue Oct 06, 2009 8:39 am Post subject: Re: Props |
[quote="HShack(at)aol.com"]In a message dated 10/4/2009 1:15:40 A.M. Eastern Daylight Time, DAquaNut(at)aol.com writes:
I have a Kiev Hot prop in new condition for sale that fits the Rotax 912 /912-S with all mounting hardware. I will sell my hot prop, but I will not recommend it. It seems lighter and more fragile than the powerfin.
Mike
Kolb MK-III Xtra, 912-S |
