		cjhukill(at)cox.net Guest
				 Posted: Sun Oct 11, 2009 5:54 am    Post subject: door pins |
				I have a set of Rivethead aero door pins and  guides. I am looking for a source for pins without the magnets, as I intend to  use microswitches instead of the magnet switch. I can then adjust the switch to  activate at the very start of any retraction, instead of the 1/4 inch or so  movement the magnet switches require. Does anyone have a source for the  pins?
  Chris Hukill
				 Posted: Sun Oct 11, 2009 6:21 am    Post subject: door pins |
				I think Iflyrv10 does ChrisRick S.
 Sent via BlackBerry by AT&TFrom:  "Chris Hukill" <cjhukill(at)cox.net>
 Date: Sun, 11 Oct 2009 06:30:32 -0700
 Subject: RV10-List: door pins
  I have a set of Rivethead aero door = pins and=20 guides. I am looking for a source for pins without the magnets, as I = intend to=20 use microswitches instead of the magnet switch. I can then adjust the = switch to=20 activate at the very start of any retraction, instead of the 1/4 inch or = so=20 movement the magnet switches require. Does anyone have a source for the=20 pins?
  Chris Hukill
		bcondrey
				 Posted: Sun Oct 11, 2009 7:23 am    Post subject: door pins |
				I'm sure Steve DiNieri (iflyrv10.com) would help you out.
 Bob
   From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com>
 To: rv10-list(at)matronics.com <rv10-list(at)matronics.com>
 Sent: Sun Oct 11 06:30:32 2009
  Chris Hukill
		jeff(at)westcottpress.com Guest
				What is stopping you from using the magnetic pins mechanically?
 On Oct 11, 2009, at 6:30 AM, "Chris Hukill" <cjhukill(at)cox.net (cjhukill(at)cox.net)> wrote:
 [quote]  I have a set of Rivethead aero door pins and  guides. I am looking for a source for pins without the magnets, as I intend to  use microswitches instead of the magnet switch. I can then adjust the switch to  activate at the very start of any retraction, instead of the 1/4 inch or so  movement the magnet switches require. Does anyone have a source for the  pins?
  Chris Hukill
		dlm46007(at)cox.net Guest
				 Posted: Sun Oct 11, 2009 7:38 am    Post subject: door pins |
				Recently I had an opportunity to examine the doors on  several other 10s. one had a cauliflower shaped hole in the rear door frame. the  irregular shape was about 5/8" in diameter. I think the hole in the door frame  should be circular and 7/16" in diameter jus as the pin. The irregular hole  is going to provide plenty of room for the door to move while  closed.
    From: owner-rv10-list-server(at)matronics.com  [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris  Hukill
 Sent: Sunday, October 11, 2009 6:31 AM
 Subject: door pins
  Chris Hukill
				 Posted: Sun Oct 11, 2009 12:41 pm    Post subject: door pins |
				Rivethead also has non-magnet door pins.
 Carl
  Sent: Sunday, October 11, 2009 9:31 AM
  Subject: door pins
 Chris Hukill
    	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?RV10-List  | 	  0123456789
		capsteve(at)iflyrv10.com Guest
				 Posted: Sun Oct 11, 2009 1:23 pm    Post subject: door pins |
				Chris,
      I can trade out the pins  (no cost), just send them to me and I'll send you the non mag pins. Also I can  sell them if you prefer to keep the old ones.
  I offer them as an option when I sell the door  guides, but I have offered in the past to change out pins from other  manufacturers and I'm happy to continue.
  just drop me a private note if you decide to send  them to me so I can watch for them.
  steve
  IFLYRV10.COM
  Sent: Sunday, October 11, 2009 9:30 AM
  Subject: door pins
  Chris Hukill
 title="http://www.matronics.com/Navigator?RV10-List
CTRL + Click to follow link" href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
		rleffler
				 Posted: Sun Oct 11, 2009 2:18 pm    Post subject: door pins |
				Probably, but if you want them this decade, probably better to go with Steve.
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carl Froehlich
  Sent: Sunday, October 11, 2009 4:29 PM
  Subject: RE: door pins
 Carl
  Subject: door pins
 Chris Hukill
    	  | Quote: | 	 		  |    http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution    | 	  01234567890123456789
  _________________ Bob Leffler
N410BL - Phase I
