		Jerry Cochran
  Joined: 10 Jan 2006 Posts: 111 Location: Wilsonville, OR
				 Posted: Tue Oct 06, 2009 8:51 am    Post subject: Crazy Transducer readings |
				Folks,
  My Fuel Flow Transducer has about 150 hrs on it hooked up to GRT Efis/EIS 4000. Worked great then took turns reading either zero or correctly. The other day, bounced  between zero and 30+GPH. Faulty transducer? EIS? Wiring? Whatcha think?
  Yes, I will call GRT, but thought I'd get feedback here first...
  Thanks all,
  Jerry Cochran
  |  | - The Matronics AeroElectric-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		ainut(at)hiwaay.net Guest
				 Posted: Tue Oct 06, 2009 9:31 am    Post subject: Crazy Transducer readings |
				foam or air in fuel lines?
 Jerry2DT(at)aol.com wrote:
  	  | Quote: | 	 		   Folks,
  Thanks all,
  Jerry Cochran
  Checked by AVG - www.avg.com
		Phil.Perry(at)netapp.com Guest
				 Posted: Tue Oct 06, 2009 12:21 pm    Post subject: Crazy Transducer readings |
				Where is it mounted in the fuel system?  What type of fuel system do you have?
 There might be some turbulence in the fuel line that’s causing an inaccurate reading.
 Phil
 From: Jerry2DT(at)aol.com [mailto:Jerry2DT(at)aol.com]
  Sent: Tuesday, October 06, 2009 11:41 AM
  Subject: Crazy Transducer readings
 Folks,
 Thanks all,
 Jerry Cochran
    	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?AeroElectric-List  | 	  0123456789
