cjhukill(at)cox.net Guest
Posted: Sun Oct 11, 2009 5:54 am Post subject: door pins |
I have a set of Rivethead aero door pins and guides. I am looking for a source for pins without the magnets, as I intend to use microswitches instead of the magnet switch. I can then adjust the switch to activate at the very start of any retraction, instead of the 1/4 inch or so movement the magnet switches require. Does anyone have a source for the pins?
Chris Hukill
ricksked(at)embarqmail.co Guest
Posted: Sun Oct 11, 2009 6:21 am Post subject: door pins |
I think Iflyrv10 does ChrisRick S.
Sent via BlackBerry by AT&TFrom: "Chris Hukill" <cjhukill(at)cox.net>
Date: Sun, 11 Oct 2009 06:30:32 -0700
Subject: RV10-List: door pins
I have a set of Rivethead aero door = pins and=20 guides. I am looking for a source for pins without the magnets, as I = intend to=20 use microswitches instead of the magnet switch. I can then adjust the = switch to=20 activate at the very start of any retraction, instead of the 1/4 inch or = so=20 movement the magnet switches require. Does anyone have a source for the=20 pins?
Chris Hukill
bcondrey
Posted: Sun Oct 11, 2009 7:23 am Post subject: door pins |
I'm sure Steve DiNieri (iflyrv10.com) would help you out.
From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com>
To: rv10-list(at)matronics.com <rv10-list(at)matronics.com>
Sent: Sun Oct 11 06:30:32 2009
Chris Hukill
jeff(at)westcottpress.com Guest
What is stopping you from using the magnetic pins mechanically?
On Oct 11, 2009, at 6:30 AM, "Chris Hukill" <cjhukill(at)cox.net (cjhukill(at)cox.net)> wrote:
[quote] I have a set of Rivethead aero door pins and guides. I am looking for a source for pins without the magnets, as I intend to use microswitches instead of the magnet switch. I can then adjust the switch to activate at the very start of any retraction, instead of the 1/4 inch or so movement the magnet switches require. Does anyone have a source for the pins?
Chris Hukill
dlm46007(at)cox.net Guest
Posted: Sun Oct 11, 2009 7:38 am Post subject: door pins |
Recently I had an opportunity to examine the doors on several other 10s. one had a cauliflower shaped hole in the rear door frame. the irregular shape was about 5/8" in diameter. I think the hole in the door frame should be circular and 7/16" in diameter jus as the pin. The irregular hole is going to provide plenty of room for the door to move while closed.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Hukill
Sent: Sunday, October 11, 2009 6:31 AM
Subject: door pins
Chris Hukill
Posted: Sun Oct 11, 2009 12:41 pm Post subject: door pins |
Rivethead also has non-magnet door pins.
Carl
Sent: Sunday, October 11, 2009 9:31 AM
Subject: door pins
Chris Hukill
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
capsteve(at)iflyrv10.com Guest
Posted: Sun Oct 11, 2009 1:23 pm Post subject: door pins |
Chris,
I can trade out the pins (no cost), just send them to me and I'll send you the non mag pins. Also I can sell them if you prefer to keep the old ones.
I offer them as an option when I sell the door guides, but I have offered in the past to change out pins from other manufacturers and I'm happy to continue.
just drop me a private note if you decide to send them to me so I can watch for them.
steve
IFLYRV10.COM
Sent: Sunday, October 11, 2009 9:30 AM
Subject: door pins
Chris Hukill
title="http://www.matronics.com/Navigator?RV10-List
CTRL + Click to follow link" href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
rleffler
Posted: Sun Oct 11, 2009 2:18 pm Post subject: door pins |
Probably, but if you want them this decade, probably better to go with Steve.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carl Froehlich
Sent: Sunday, October 11, 2009 4:29 PM
Subject: RE: door pins
Carl
Subject: door pins
Chris Hukill
| Quote: | | http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution | 01234567890123456789
_________________ Bob Leffler
N410BL - Phase I
