		rebrunk42(at)gmail.com Guest
				 Posted: Fri Oct 09, 2009 7:10 am    Post subject: flap switch |
				initially, my flap switch would engage in three increments, but now I
 have to mark my flap so i can manually lower it to its proper position
 for landing . what happened to the mechanism, and what is the fix? as
 always i appreciate all the wisdom. robert  brunkenhoefer  KCRP
 flying in conditional.
				 Posted: Fri Oct 09, 2009 8:34 am    Post subject: flap switch |
				If you have the flap positioning system, then it is possible that
 either one of the switches is bad or the rod is somehow messed up.  It
 is more likely that the controller is bad.  If the controller is
 working and one of the switches or rod is bad, then I would think that
 when you hit the flaps-down switch, it would go all the way down and
 the motor would keep on running because there would be no "limit
 switch" for the different position settings.  I have seen one system
 where the flaps went just beyond the last switch, so when the flaps
 stopped in the "down" position, if you hit the switch again they would
 go just beyond that position and the motor would keep running.
 Jesse Saint
 Saint Aviation, Inc.
 jesse(at)saintaviation.com
 Cell: 352-427-0285
 Fax: 815-377-3694
 On Oct 9, 2009, at 10:44 AM, Robert Brunkenhoefer wrote:
  I have to mark my flap so i can manually lower it to its proper
  position for landing . what happened to the mechanism, and what is
  the fix? as always i appreciate all the wisdom. robert
  brunkenhoefer  KCRP  flying in conditional.
		Nick Leonard
  Joined: 18 Jun 2007 Posts: 35 Location: Sacramento, CA
				 Posted: Fri Oct 09, 2009 9:45 am    Post subject: Re: flap switch |
				I am so glad that you brought this subject up.  I have been looking at developing a flap positioning system initially for my own use but with an eye on making it available to others.
 The system would use one of two flap switches - either a rotary switch (ala Cirrus and others) that has a flap like handle that you click to the desired position.  The other switch format is like the Cessna vertical flap selector.  Different panel switches but the functionality would be the same.  In both cases, lights would indicate current position, selected position and transition state.  The system would be 12v or 24v and have multiple outputs for displaying the flap position on various electronic panels (Dynon, AFS, GRT, etc). Unlike the other flap positioning systems, you would lose the ability to stop the flaps between positions.
 So my question is; is this a one-off project for myself or would others be interested in such a system?  I would expect the pricing to be in the same range as the other flap positioning systems.  What additional features might you want to see?
 Thanks for your feedback. -Nick
  _________________ Nick Leonard
RV-10 (40015) Flying |
		msausen
				 Posted: Fri Oct 09, 2009 10:34 am    Post subject: flap switch |
				This is just me thinking out loud here but given the fact there are at least 3 other systems today, I don't know if it would be worthwhile for even yourself.  I'm betting the $time$ involved for the one off would probably cost more than one of the COTS models.
 Michael
		Nick Leonard
				 Posted: Fri Oct 09, 2009 11:49 am    Post subject: Re: flap switch |
				Michael,
 You may well be right but what I'm building can't be adapted from one of the existing systems.  In fact, I have one of them now that I bought some time ago.  Personally, I would prefer the rotary switch approach and I have access to someone who can design the electronics so it should be an enjoyable project.
		billderou(at)yahoo.com Guest
				 Posted: Fri Oct 09, 2009 7:00 pm    Post subject: flap switch |
				Robert-
  Suggest you stop and debug the situation. The motor could be running up against a stop when you think it is off. This could harm something and/or create a serious situation.
  During my installation I noticed that the flap motor will rotate the worm drive shell (say) clockwise when dropping the flaps and CCW when retracting the flaps. This causes the flap sensing rod to rotate and the microswitch rollers miss the detents. My suggestion is open the tunnel and watch the action as the flaps are lowered and raised. Maybe this will help in the problem resolution process.
  Bill DeRouchey
  N939SB, 320 hrs
 --- On Fri, 10/9/09, RV Builder (Michael Sausen) <rvbuilder(at)sausen.net> wrote:
 From: RV Builder (Michael Sausen) <rvbuilder(at)sausen.net>
 Subject: RE: Re: flap switch
 To: "rv10-list(at)matronics.com" <rv10-list(at)matronics.com>
 Date: Friday, October 9, 2009, 11:33 AM
  --> RV10-List message posted by: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net (rvbuilder(at)sausen.net)>
 Michael
		cjhukill(at)cox.net Guest
				 Posted: Sat Oct 10, 2009 5:17 am    Post subject: flap switch |
				I would be interested in another system for  controlling the flaps than Vans provides in they're version of the flap  positioning system. In my RV8, I have a simple momentary up, off, down switch.  Works great, lasts a long time. I look out over the left shoulder, and can see  the marks on the flaps, and just release the switch at the desired setting.  I have been flying a RV10 with the Vans positioning system installed, and  it seems to be more work (i.e. distraction), to get the flaps where you want  them, than to just hold and release the switch, like in my 8. Now with the  realization that the positioning system adds several failure points to the  equation, I think I am going to pass on it. I don't need a burned out actuator  while far from home. At least a "flap motor running" annunciator would be a  requirement for any system that can fail in that mode. I have flown the Cirrus,  and would be very much interested in a similar system to that. I think I'll walk  down to the local Cirrus service center, and check the price on one of those  switches, and logic boards, and talk to the mechanics on the reliability and  safeguards of that system. I will post my findings.
  I am about to figure out how to mount the RAC 1.2  inch position sensor to the flaps. Anybody got pictures of how they did  it?
  Chris Hukill
  temporarily out of fiberglass  hell
		Tim Olson
				 Posted: Sat Oct 10, 2009 6:17 am    Post subject: flap switch |
				Not sure what you mean that it's more work than your 8.  With the
 standard positioner, it's just press and release just like you
 say.
 Tim Olson - RV-10 N104CD
 Chris Hukill wrote:
  	  | Quote: | 	 		   I would be interested in another system for controlling the flaps than
  Chris Hukill
		ScooterF15
				 Posted: Sat Oct 10, 2009 11:18 am    Post subject: flap switch |
				[quote] There's pictures of my RAC POS-12 sensor install in this previous post here: http://forums.matronics.com/viewtopic.php?t=38195&highlight=pos12
  Also, I've been having trouble with my Van's flap positioning system lately. I've done some trouble shooting but haven't yet pin pointed the issue. It tends to stop at random places on the way down.
  -Jim
  40134
   On Sat, Oct 10, 2009 at 7:03 AM, Chris Hukill <cjhukill(at)cox.net (cjhukill(at)cox.net)> wrote:
   	  | Quote: | 	 		    I would be interested in another system for controlling the flaps than Vans provides in they're version of the flap positioning system. In my RV8, I have a simple momentary up, off, down switch. Works great, lasts a long time. I look out over the left shoulder, and can see the marks on the flaps, and just release the switch at the desired setting. I have been flying a RV10 with the Vans positioning system installed, and it seems to be more work (i.e. distraction), to get the flaps where you want them, than to just hold and release the switch, like in my 8. Now with the realization that the positioning system adds several failure points to the equation, I think I am going to pass on it. I don't need a burned out actuator while far from home. At least a "flap motor running" annunciator would be a requirement for any system that can fail in that mode. I have flown the Cirrus, and would be very much interested in a similar system to that. I think I'll walk down to the local Cirrus service center, and check the price on one of those switches, and logic boards, and talk to the mechanics on the reliability and safeguards of that system. I will post my findings.
  Chris Hukill
		dlm46007(at)cox.net Guest
				 Posted: Sat Oct 10, 2009 12:55 pm    Post subject: flap switch |
				I used a momentary switch from McMaster Carr. The switch is  spring loaded to move down flaps. Returns to center position to shut off  the flap motor. When the switch is flipped up the flaps move up until switch  returned to center. I have a red LED wired in the circuit to remind me if I left  the switch in the up position and the motor is running. Of course I also have a  starter running light as well.
    From: owner-rv10-list-server(at)matronics.com  [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of  Bob-tcw
 Sent: Saturday, October 10, 2009 8:59 AM
 To:  rv10-list(at)matronics.com
 Subject: Re: ***SPAM*** flap  switch
  Chris,   You may want to take a look at  our Flap Controller.  It works with the standard momentary down,  maintained up type flap switches.  The TCW flap controller allows  for pilot and co-pilot flap switches, it includes a 15 second run timer to shut  off the flap motor if you leave the flap switch(es) in the up  position.   The flap controller takes care of the conflict  if one of the flap switches is left in the up positon.  It also connects to  an airspeed switch providing vfe protection.
  All the details are at www.tcwtech.com
  Bob Newman
  [quote]   ---
		marcausman
				 Posted: Sun Oct 11, 2009 10:35 am    Post subject: Re: flap switch |
				You might also consider that the flap system behaves slightly differently in the air than on the ground, due to the air loads. Some people report problems in the air but not on the ground.
  _________________ Marc Ausman
http://www.verticalpower.com  "Move up to a modern electrical system"
RV-7 IO-390 Flying |
