rickofudall
Posted: Mon Oct 12, 2009 7:41 pm Post subject: Angle measurements |
Couldn't sleep so I went to the hangar and set Zulu Delta up with horizontal stab level.- Boom tube 4.5 degrees up toward aft
- Wing bottom 7 degrees
- Engine tube 5 degrees down toward aft
Hope this helps
Rick Girard
